Old 01-17-2005, 02:22 PM
sc sc is offline
Default MIDI SETUP: Digi 001, ver 6.1 + Yamaha dtx 2.0
I am running Digi 001 with Windows XP, Version 6.1. I have a Yamaha DTX 2.0 electronic drum kit and am trying to setup the DTX with PT via midi. My goal is to be able to play and record the DTX into seperate MIDI tracks( track for each trigger ) and later bounce this to audio. ( I have done this using REASON 2.5 ( AS A PLUG IN) , writing the patterns,etc - 1 aux.track, 1 midi track and out to audio track ).
Problem - PT does not see the DTX. I have used the same midi cables from my Korg keyboard into PT/REASON and can play samples, so I know cabling is right. I also have two outputs from the keyboard into PT as well ( should it matter)? The DTX SEND/REC channels default to channel 10; as a device option, whether in Reason or PT, I don't see the DTX as MIDI input device ( should I )???
The PT 6.1 reference manual only gives the midi setup steps for a MAC system - doesn't help. What I need to be sure of is, from the PT/001 side, am I setup right. If so, then I know my problem is with the DTX.
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup xxicjoy MIDI 69 08-02-2013 08:40 PM
Three MIDI ports on DIGI 002R within MIDI studio Setup Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-18-2010 04:57 PM
Yamaha Motiff ES Midi setup in LE...........Help! Ratava1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-22-2005 05:44 PM
Need Help!!! Midi setup for Digi002 and Yamaha ES6 BlasDON 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-19-2005 06:28 PM
Help! Yamaha Motif Midi Setup with Protools LE 6.4 Warrioress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-09-2004 07:12 PM
