Old 10-19-2021, 02:02 PM
Samba Samba is offline
Default Pro Tools ignoring sustain messages
Has anyone had this issue?
On an instrument track, using Kontakt/AliciaKeys - Pro Tools ignores lots of the sustain messages. The sustain has initially been played in with a sustain pedal.
The pedal is working fine. All sustains look fine, but pro tools just ignores them.
is it possible that Kontakt has issues with pro tools?
Old 10-19-2021, 03:08 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Pro Tools ignoring sustain messages
I used to have the problem with sustain on punch-ins but I think the option in preferences for MIDI Merge Release Mode helped with that.
Have you tried another plugin like MiniGrand to see if it still happens?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-19-2021, 10:40 PM
Thanks Chris. I'll give it a run tonight
Old 10-20-2021, 10:47 AM
Eric Lambert's Avatar
Known problem with Kontakt and Alicia's Keys. The fix is to create more space between sustain ons and offs at points where MIDI is being ignored. AK, for whatever reason, doesn't like quick pedal switching. I have a couple other Kontakt-based pianos that behave this way, occasionally, but nowhere nearly as often as AK.
Old 10-20-2021, 02:31 PM
Philthy Philthy is offline
Kontakt sustain is a mess on my rig too, using galaxy vintage d
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 10-20-2021, 03:47 PM
Yep, that's the other piano library I struggle with in this regard, though I don't find it to be as bad as AK.
Old 10-20-2021, 03:51 PM
AIR Mini Grand does that too, on and off, unpredictable. Ivory seems to not be affected about this, but I am thinking it is more of a midi merge issue than a plugin problem. Still wondering why some of the plugins work and others do not, which would imply plugin problem.
This has been on and off since PT8 so if you want to get rid of it you need to go back to 7.4.2 version.
Old 10-21-2021, 06:08 AM
Progear Progear is offline
Same here, spent an hour yesterday trying to figure out the sustain problem but was not able to fix… it happens with all of my instrument plugins including mini grand.. HELP.. !!!!!
Old 10-21-2021, 10:52 AM
daeron80 daeron80 is offline
Working fine with eastwest and Spitfire pianos, tho. Even Kontact-based Spitfire libraries don't seem to be afflicted on my system. PT 2021.6, Windows 10, 24-core 2.3 GHz Xeon.
David J. Finnamore
Old 10-21-2021, 02:12 PM
john1192 john1192 is offline
had a perfect piano part never be the same as there was NO SUSTAIN info Recorded ... trying to add that later never worked right ..
I do Not use Pro Tools for Pianos anymore .. never want to go through that again ...
my .02
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Sustain messages when recording Samba MIDI 3 07-23-2020 08:04 AM
Sustain NOT recording in pro tools 9!!! geoffvernon Pro Tools 9 7 03-29-2014 04:38 PM
Many different error messages, Pro Tools aborting or unable to click messages off riffmachine Pro Tools M-Powered (Win) 5 10-05-2010 04:15 AM
midi sustain pedal messages bug dmuckala Pro Tools TDM Systems (Mac) 34 09-11-2007 10:32 PM
Ignoring Buffer Messages Seven Harkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-22-2003 11:11 PM
