Old 08-29-2021, 01:38 PM
scenaria scenaria is offline
Default Anyone ever successfully restore firmware to an Omni
That says “no firmware” it’s dead only has amber power light. I’ve tried a ton of digitest versions even back to PT10 erra. No luck. Usually will say erasing firmware and then hang at that point or hang at 0 percent.
I find it simply retarded that they designed a product that can erase firmware but not restore it.
There must be a low level utility that can plug into main board and allow firmware restore.
Old 08-29-2021, 05:48 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Anyone ever successfully restore firmware to an Omni
Contact support then. The update process may hang for a while but should not be quit before Omni restarts itself. What does the DigiTest say about your unit?
Janne
Old 08-29-2021, 08:49 PM
Attached is a pic of the digitest. The one is from when it froze and shows current version 1.11 With target as 2.10. Then I tried re running with older version of digitest and it shows no current firmware
File Type: jpg 71595133-26FB-4D32-8280-4E0567663CEA.jpg (63.0 KB, 0 views)
File Type: jpg F9925733-694E-4579-9470-81BE6368FD68.jpg (75.9 KB, 0 views)
Old 08-29-2021, 09:33 PM
JFreak's Avatar
Before you contact support, have you tried unplugging digilink cable, pressing setup button, scrolling to reset?
Janne
Old 08-30-2021, 11:19 AM
Front panel is dead. Only thing that lights is amber power button. And yea I’ve tried pressing setup and applying power with no response.
Old 08-30-2021, 12:35 PM
JFreak's Avatar
Other than random tip of trying a firmware update again with a pre-12.4 digitest version, I would say you need to contact support.
Janne
Old 08-30-2021, 01:20 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I have an OMNI where the front panel will freeze constantly on power-up. It sounds ridiculous, but give it a "gentle" hit underneath it. Maybe a little harder than gentle. Mine comes back to life and all of the displays, buttons, and knobs function again.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 08-30-2021, 06:09 PM
LDS LDS is offline
I had an Omni that I thought was dead, but it turned out that the contrast settings had changed and blanked out the screen. It happened completely out of the blue. Is there any chance these things have a little battery in them that may need replacing after some years?
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
HD OMNI - No firmware, can't install one. BaroqueWorks Pro Tools HDX & HD Native Systems (Win) 2 02-13-2020 09:43 AM
PT HD Omni sin firmware Limoncarro Foro en Español 2 05-04-2016 06:30 AM
The Sticky about the Omni Firmware YYR123 Pro Tools HDX & HD Native Systems (Mac) 5 04-25-2016 03:13 PM
Omni firmware ver. and HW rev. for PT12 maunaloa Pro Tools HDX & HD Native Systems (Win) 2 05-15-2015 05:49 PM
HD Omni firmware update CDac Pro Tools HDX & HD Native Systems (Mac) 3 08-01-2011 11:27 AM
