Old 03-02-2007, 09:27 AM
SoundtrackArcade SoundtrackArcade is offline
Default 1024 buffer vs. 2048 ??
hi.
maybe a dumb question: I just upgraded from the mbox2 which offered the 2048 buffer size and now I am on an 002 and my highest option is 1024. Any reason why that is? Is there a way to get back up to 2048? (I am having some major problems with crashes due to low cpu and "needing a higher playback buffer." I realize that's a problem that alot of people are struggling with.)
thanks.
Old 03-02-2007, 10:43 AM
twix twix is offline
Default Re: 1024 buffer vs. 2048 ??
only time I can use 2048, is with 96k.
Old 03-02-2007, 01:03 PM
interesting...thanks for the heads up. I am still (only very recently) having some MAJOR issues with the buffer size. I can't record for more than 20 seconds without getting the "increase your buffer size" warning. Terribly frustrating as you probably know. Any tips there? Is it my computer or Pro Tools more likely?
Old 03-02-2007, 01:28 PM
The Dougfather The Dougfather is offline
Dude, you should be able to get your buffers down to 64 when recording with an 002, the high buffers are more for mixing and plug count. As an Mbox user i've never had a problem with 1024 samples. You need to post your mac spec, OS version, Pro Tools version to get more help.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
RME ASIO 1024 sample buffer - possible w/PT9? iain_m Windows 0 03-30-2012 03:22 PM
Buffer Engine now only goes up to 1024? anackman macOS 7 10-01-2011 12:50 PM
1024 buffer max, used to be 2048 in PT8 Sturphy Pro Tools 9 8 12-02-2010 07:53 AM
H/w buffersize from 2048 to 1024 Zino Mikorey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-15-2010 11:53 PM
Is 1024 the highest buffer setting in 7.4 LE? JChance 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-24-2008 05:00 AM
