Old 01-06-2005, 01:20 PM
CHEEZGRITS CHEEZGRITS is offline
Default WIDEN THE STEREO IMAGE
I feel I've carved good eq holes, sufficient punch with drums, and overall warmth sonic individuality among the tracks. But I feel like I can make the stereo image wider. Any hints or tricks on how to achieve this. (I only have plug-ins, no outboard equip)
all aboard. next stop...the road less traveled!
Old 01-06-2005, 02:42 PM
double double is offline
Default Re: WIDEN THE STEREO IMAGE
depending on what stage you're looking to add width, the Waves S1 works pretty well. you dont have to over do it, a little goes along away. if you're widening at the mastering stage, you might find some good results by just applying it on a stem without the lead vocals. i use the S1 in moderation all the time.
www.prestonpope.com
G5 Dual 2.7 OSX 10.4.5
PT HD 7.3.1cs3
Old 01-10-2005, 07:50 PM
barznbeats1 barznbeats1 is offline
Cheezgrits... maybe you can answer this question...
Okay, I'm running PT LE 6.4 on a Digi 002r with a Mackie Control Universal. The 002r has 1 midi in 2 midi outs. The Mackie has 1 midi in 1 midi out. Here's the problem... I have a Triton Extreme which I would like to fit into it all but it has 1 midi in 1 midi out 1 midi thru. How can I get it all working? What I'm trying to do is sync em all up because the triton only has 4 line outs and for me to record 16 tracks I would have to do it 4 times, 4 tracks at a time and that would be hard if I didnt have em sync'd. Should I buy a usb midi interface? I mean.. If its not digidesign will it be recognized by pro tools?? I'm stuck dawg. Any help would be greatly apreciated.
Thank You.
Old 01-10-2005, 08:07 PM
bb_aus bb_aus is offline
Thank You.
has nothing to do with the origional question but get an edirol UM series USB MIDI interface ive never had any problems and they have been tested by digi to work with PT. for the most part the midiman interfaces are fine aswell however there have been a few issues especially when used with controll surfaces so i stick with the edirol to be safe
also you would most likley be best served with a 2 or more port as your equipment will always grow
Old 01-10-2005, 09:19 PM
***this reply is to barznbeats1 ***
well i'm using mbox and i've incorporated a usb hub. I have midi up'd my mpc 2000xl, boss sp-505 and my keyboard to the usb hub and it's flawlessly sync. I do hip-hop and r&b and I have no probs
Old 01-10-2005, 10:06 PM
Thank you both for the help! I will be ordering an edirol with the 8 in 8 out. I do hip hop and r&b too Cheezgrits which is why I though you might be running a similar setup. Anyhow, I know it had nothing to do with the original thread but again, thank you both. I posted the question in other places and got alot of views but no replies.
Old 01-10-2005, 11:50 PM
freed freed is offline
good question dude - something i've been thinking about on certain tracks, and thanks double for the response, i dont know if i can bring myself to buy Waves especially after an article i read on the copy protect devices they use being very, very unstable.....i dont feel theres much of an option though
Old 01-11-2005, 02:20 AM
will the moor will the moor is offline
some of these have worked for me, your milage may(will) vary...
to spread out something like an acoustic guitar, copy the track twice. Filter out everything except, say 8-10k on one and 10-12k on the other. pan them both hard left and right. and/or, try flipping the phase on one of them.
stereo reverb
stereo delay
phasing tricks of any variety.
there's loads of vst spatial doo-dads. if you dont have the rtas>vst adapter, get it! best 100 bucks you can spend on pt.
good luck.
will
http://soundofthatday.com
Unable to Get Stereo Image arturoinletto Pro Tools 11 6 01-08-2014 10:14 PM
Stereo Image! MetalDrmr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2008 07:51 PM
Stereo Image? Oroz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-29-2005 02:33 PM
How to widen stereo image Ping Pong Tips & Tricks 6 09-05-2004 09:14 AM
Wide stereo image. Ben Jenssen Tips & Tricks 20 08-12-2002 02:56 AM
