Editing MIDI notes is sometimes not possible
In this session I have an instrument track running VSL Vienna Synchron Player. Some notes I can edit (move note values, change durations, change velocities) and some - on the same track) I cannot.
There appear to sometimes be two identical notes at once and sometimes you can move one of them (revealing the one beneath) and sometimes not. You can't even grab some of the notes. They're just there. If I move to Block view I can delete a section and that deletes the note underneath. But this is only half a solution. |
Re: Editing MIDI notes is sometimes not possible
If I copy and paste the MIDI notes into an empty MIDI track, and the mix automation into an empty audio track, then clear the instrument track and paste the notes and the Automation back in, I can edit the notes freely again.
What happens if you, on the original MIDI track, select all, then Event menu & select "Remove Duplicate Notes" . . ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Midi notes deleting when editing and writing in notes | SeventhSounding | MIDI | 5 | 01-14-2018 02:34 AM |
Editing Midi Notes | teacherman | MIDI | 4 | 06-05-2008 02:55 PM |
Editing Midi Notes | 4times4mil | Tips & Tricks | 3 | 03-21-2007 04:14 PM |
Editing Midi Notes | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-26-2006 02:01 PM |
Lag editing MIDI notes | Electrohermit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-11-2004 02:06 AM |
