#121
Re: HDX smokes HD2
If you want the low latency you have to use HDX and AAX DSP plugins. But in that case you will need at least an HDX2 to open the session that will run on HDN. At least from looking at those screen shots.
If you´re fine with higher latency you are fine with an HDX1. But then: Why use HDX1 if it will play fine in HDN? I know it does´t fully compare since you have die DSPs in addition on HDX. But I think it´s quite remarkable that you need an HDX2 to play back a session (and that will be quite full in terms of chips) from HDN when using AAX DSP. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#122
I don't know but I guess is more cause the computer has to handle the mixer as well.
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
#123
Re: HDX smokes HD2
I posted that earlier.
#124
Re: HDX smokes HD2
#125
Re: HDX smokes HD2
For comparison sake...
My computer is a westmere (5,1) 6 core 3.33 ghz.. w/16gb ram.. The MAKEITCRASH native session was opened with buffer at 256 and 11 processors.
#126
Re: HDX smokes HD2
I know. I wasn´t saying that HD1,2,3 had different latency.
#127
Re: HDX smokes HD2
You mean this?
http://www.protoolsprofessional.com/...4.12.32-PM.png HD3 Accel is used there, not HDN. I guess I am missing something? |
#128
Re: HDX smokes HD2
I think you read my post wrong.. Please read again. Lynx Aurora and Apogee systems are INDEED supported by AVID now in the sense that they actually have jacks on their cards that plug directly into Digi Hardware. I should know - I work at a studio that has an Aurora that attaches directly via a DigiLink cable to their HD3 system. That support 'connectivity' will be discontinued at PT 11. Whereas with PT9HD and 10HD running - all HD|Accel hardware and Aurora and Apogee hardware all still work connected directly to the Core card.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#129
Re: HDX smokes HD2
Unless you mean something else when you say "supported". |
#130
Re: HDX smokes HD2
For me the essential info is that a big session from an HDN system can be impossible to play back on HDX1 if you want to run fully AAX DSP on HDX. So if you think of the PR tag line: "HDX1 is around 5xHD" it can mean that HDN can be almost 2xHDX. ;-) In the end they all have their up and down-sides. But one thing´s for sure: HD accell is the least powerful in terms of voices and processing power. So coming back to the original posting: For me the actual surprise isn´t that HDX smokes HD. It´s the info that HDN can be equivalent to HDX1 Frank.
Edit Smoothing smokes on a G5! | bassmac | Pro Tools TDM Systems (Mac) | 0 | 02-03-2005 06:21 PM |
