PT 8.0.4 random errors
Hi!
My PT 8.0.4 is acting really wierd. Buffer size errors, stops passing audio, clicks and pops, distorts, clock problems etc. PLZ Help! I've tried everything from going back to XP to going thru Avid's optimzation list to inactiviating soundcards etc. Nothing works PT is still acting wierd. Sendra: Computer Model : HP HP EliteBook 8540p Domain : IT Host Name : LLD115LT User : - Processor Model : Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz Speed : 2.53GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 4 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : HP 1521 BIOS : HP 68CVD Ver. F.08 04/28/2010 Bus(es) : X-Bus PCI PCIe IMB PCMCIA CardBus USB FireWire/1394 Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DDR3 SO-DIMM Chipset Model : HP Core (Auburndale/Havendale) DRAM Controller Front Side Bus Speed : 1x 133MHz (133MHz) Total Memory : 2GB DDR3 SO-DIMM Channels : 1 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : LG EBJ21UE8BDS0-DJ-F 2GB DDR3 SO-DIMM PC3-10600U DDR3-1332 Video System Video Adapter : NVIDIA NVS 5100M (32 SM4.1 1.2GHz, 1GB DDR3, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA NVS 5100M (48SP 6C 1.2GHz, 986.6MB) Compute Shader Processor : NVIDIA NVS 5100M (32SP 1.2GHz, 986.6MB) Storage Devices TOSHIBA MK2556GSY (250GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 233GB (C:) (F:) hp DVD RW AD-7586H (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 385MB (D:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (E:) Logical Storage Devices BDEDrive : 300MB (NTFS) OSDisk (C:) : 135GB (NTFS) @ TOSHIBA MK2556GSY (250GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Inspelning (F:) : 98GB (NTFS) @ TOSHIBA MK2556GSY (250GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Audio CD (D:) : 0bytes (CDFS) @ hp DVD RW AD-7586H (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : HP QM57 LPC Interface Controller LPC Legacy Controller 1 : SMSC FDC37B72x Audio Device : HP P55/PM55/3400 High Definition Audio Audio Codec : Integrated Device Tech 7603h Audio Device : HP High Definition Audio Controller Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : HP P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : HP SD Bus Host Adapter USB Controller 1 : HP P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : HP P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 3 : HP uPD720200 USB 3.0 Controller FireWire/1394 Controller 1 : HP R5C832 IEEE-1394 Controller CardBus/PCMCIA Controller 1 : 12284 RL5c476 CardBus Controller Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Printer : Kyocera TASKalfa 400ci KX (600x600, Colour) Printer : Kyocera TASKalfa 400ci KX (600x600, Colour) Printer : Kyocera FS-C1020MFP PCL 6 (600x600, Colour) Printer : KONICA MINOLTA C252/C252P VXL (600x600, Colour) Network Services Network Adapter : Intel(R) 82577LM Gigabit Network Connection (Ethernet, 100Mbps) Wireless Adapter 1 : Intel(R) Centrino(R) Advanced-N 6200 AGN (802.11a (OFDM), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 98% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.5 |
Re: PT 8.0.4 random errors
disable the nvidia video driver and uses the windows default driver....i have nearly the same system has you and had the same problems....thats what helped me.....
Where is your separate hard drive for recording?
I have the same computer with the exact same problems. Have also tried with an external harddrive but with no luck. Hope that someone at digidesign reads this and can come up with a solution. The problem is urgent. I have about 80 students who's got this laptop and needs to work with protools.
Regular advice:
Disable wireless and regular network. You need a separate drive for Audio. Nvidia graphics driver, as mentioned. Which interface do you use? @lindjohan How do you connect the external HD?
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Random -6101 errors | RobAnderson | macOS | 5 | 02-17-2011 09:58 AM |
Getting random 9073 errors | tedcanman | Windows | 8 | 12-19-2010 12:52 PM |
random 6085 6087 errors | stratoj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-01-2006 07:42 PM |
-9073 and -6086 DAE Errors RANDOM, RANDOM, RANDOM | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-13-2004 01:08 PM |
random -6042 errors (PCI bus is too busy | dodged forgottenn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-14-2001 09:10 PM |
