Old 06-01-2007, 01:16 PM
Barry Johns Barry Johns is offline
Default HD and RTAS Plugs, Why Buy TDM Plugs
I've recently purchased an HD1 Accel system and run it on a MacPro 2.66 with 5 Meg of Ram. To date, I have been using Massey TDM plugs as well as RTAS Waves SSL, and UAD plugs. All has worked flawlessly so far. I've not come close to maxing out my HD1. My original plan was to buy another Accel card right away, but now it's got me thinking. Am I missing something, why would I buy TDM plugs when I can use RTAS, especially at the mixing stage? I get that for tracking, TDM plugs are the way to go, like Soundtoys and others. I also get for some plugs that are TDM only. For example, I want to get Waves V bundle. When I've got a MacPro and can run tons of these plugs when mixing, why would I spend double just to use them TDM?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-01-2007, 02:06 PM
IO Composer IO Composer is offline
Default Re: HD and RTAS Plugs, Why Buy TDM Plugs
5 Megs is not a lot of RAM. You should get more
If you're running the latest uber-core Mac, you'll actually get significantly more power from RTAS than you will with a fully decked out HD3Accel system. There really is no advantage to TDM plugs in the scenario you're describing.
-Jamey
Jamey Scott
Dramatic Audio Post, Inc.
Burbank, CA
IMDB
Old 06-01-2007, 08:14 PM
Matt_G Matt_G is offline
Here is some more reasons to consider using RTAS plugs in a HD system... TDM vs RTAS plugin distortion
Matt
Mastering Engineer
www.matthewgraymastering.com
Brisbane Australia
Old 06-01-2007, 08:29 PM
Steve MacMillan Steve MacMillan is offline
TDM plug-ins have much lower latency, so they work better for keeping compensation low. This is important if you are recording into a mix or streaming audio from another computer (ie Logic). RTAS plug-ins by themselves do not work on a track that is in input. Some plug-ins are TDM only.
STeve
macmandigital.com
HD PLUGS vs RTAS thenewnoise Pro Tools TDM Systems (Mac) 2 12-07-2009 04:34 AM
Can I try PT8 with RTAS Plugs again yet ? Lizardpoint Pro Tools TDM Systems (Mac) 3 08-08-2009 04:40 PM
HELP PLEASE! Mix Plus 5.1 - RTAS plugs gone? Rockman-Songwriter Pro Tools TDM Systems (Mac) 1 11-10-2006 09:55 AM
TDM plugs vs. VST/RTAS and so on Compression Records Tips & Tricks 3 02-04-2001 02:56 PM
RTAS Plugs Andy Seward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-20-2000 10:59 AM
