Disappearing I/O Set Up Files
The other day my custom I/O set-up file just disappeared. Has anyone else had this happen to them ?
I think it may have happened when I re-installed PT. Doesn't PT save your I/O set up files when you re-install it ? |
Re: Disappearing I/O Set Up Files
I think if you load an old session it will load the i/o setup that was used then? and then save it from the i/o menu! there's an option when loading a new session to use "last used" i/o setting or something like that! anyway i'm sure you can load a previous sesson and keep the i/o setup then save it again. No PT doesn't back-up your files for you! you have to do it yourself! keep a back-up of all your digidesign folder? the one in applications and the one in applications support! these 2 folders house almost everything to do with PT. I often used to lose my midi patchnames and my i/o settings etc. Chris
Hi Chris,
I do know about the "use last IO" option and I can export my IO from a previous session. But sometimes I make small alterations to my IO as I go. You know re-naming Busses for my favorite reverb of the month... stuff like that. So each session might have a slightly different IO. I was just wondering why my saved IO file just disappeared. Thanks for the advise I'll keep a copy of my Digi folders from now on. |
Session Files Keep Disappearing | barrybarry45 | Pro Tools 10 | 13 | 05-05-2017 02:21 PM |
disappearing export files | Assorted Cheeses | Pro Tools SE and Essential (Win) | 0 | 03-13-2012 05:20 AM |
Help ptf files are disappearing | trademark2386 | Pro Tools M-Powered (Mac) | 1 | 05-02-2010 01:42 PM |
Files disappearing?! | StonegateSound | Pro Tools TDM Systems (Mac) | 2 | 11-25-2004 11:57 AM |
Disappearing Fade Files | MichaelL | Pro Tools TDM Systems (Win) | 2 | 05-09-2000 02:42 PM |
