7.3 and plug in allocation
I just upgraded to PT 7.3.1 [TDM] and I am running into a curious situation. I'm on a dual 2.0 G5 Power PC Mac, with 2 G of RAM. My PT system has one original HD Core,one Accel Process card, and one original HD Process.
The issue is this : It seems most of my plugins that will work on both Accel and regular Process cards are racing to fill up the Accel card, but won't re-allocate to the Process or Core card when I open other Accel-only plugins. When I try to open an Accel only plugin, I get the DAE #-7401 error message -- instead of the program moving those items that could work on the other chips off of the Accel card [like Filter Bank, or the Sound Toys plugins -- for example]. The Process card is working, because the HD engine is using a chip on it without a problem, and plugins do open up on it. Is anyone else running into this? I can provide more details if necessary... thanks, John
www.jpreceng.com |
Re: 7.3 and plug in allocation
Hi John,
I had similar problems. Did this just start happening when you went to 7.3 ? I'm on 7.1cs10 and still having the same problems. I think it bears more discussion and explaination here. I have yet to hear a good explaination as to why certain plug ins don't load or allocate properly when there is space available. Anyone ? |
Hey Jeremy --
I've just noticed it when I upgraded to version 7.3. I've had zero problems with it before. John
www.jpreceng.com |
I know I've rehashed this question a billion times, but is there any chance of old/incompatible plug-ins being installed?
For some reason, the system is just not freeing up the Accel card for Accel-only plugins. It tries to re-allocate the plugins, but things like the Fairchild 660 and Filterbank are staying on the Accel when there are 4 DSP's still available on the Process card. Could this be an older HD/computer vs a newer HD/computer system [newer computer, new PCI type] issue -- tests correctly on the newer stuff, but has issues with slightly older computer/cards? thanks, John
www.jpreceng.com |
What version of Pro Tools were you running on this system previously?
Now, I hate to belabor the point, but I have to because it's of the absolute utmost importance - having just one incompatible plug-in in the plug-ins folder can cause strange behavior in Pro Tools. Now, if you're not sure that you have compatible plug-ins installed, you should list every plug-in in your plug-ins folder and it's version number so that I can look over them. Also, after updating the plug-ins, you should trash all preferences files so that the plug-in data can be re-cached. If anyone else is experiencing similar symptoms, please let us know - including the details of your system. |
DSP Allocation | DAS-Mike | Pro Tools TDM Systems (Mac) | 1 | 01-05-2008 11:12 PM |
ram allocation | Jasperdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-13-2005 05:00 PM |
Increasing Memory Allocation for Plug ins | ansanity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-02-2005 11:21 PM |
6.4.1cs.1 Bug with DSp allocation! | Kurtstudio | Pro Tools TDM Systems (Mac) | 0 | 10-18-2004 12:45 PM |
HD3 Accel track and plug allocation? | tlester | Pro Tools TDM Systems (Mac) | 1 | 10-07-2004 09:50 AM |
