How do I cope with mixing large sessions?
Just looking for some tips to help with mixing large sessions.
I have lots of recording coming up.. I will most likely leave the same session open to record multiple takes and multiple songs. My question is.. Let's say I mix the first song of the session and I'm happy with it.. How can I economically then use those same settings for the other mixes (songs in the same session) and tweak them as required? I know I could just leave the same session open but any changes would be saved.. I'm thinking it would be nice to have a separate session with each song and the ability to use the same plugs and settings from my first initial mix.. I'm looking for a smart method of working with mixes that are related to each other.. Any wisdom is much apprectiated. |
Re: How do I cope with mixing large sessions?
not sure if i understand you...when you are ready to work on the new session, just open up the original session and click FILE-SAVE AS, and rename that session as your new one. then all the same plugins are available.
When you get it set up the way you want, then use File > Save Copy In and don't copy any audio files. Then you can go into the Finder and set it up as read-only stationary. The next time you open it in PT, it will ask if you want to modify the template or create a new session from it.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Hi.
Try these tips... Save all of your Plug in settings for each track. Then Label your Aux Sends and Returns In the Session IO set up. Export your IO Set Up and save it as "New Album IO" or something like that. Now you can open your new song as usual and Import Session Data from your first song. Only Import Aux's (effects) not the Audio tracks and then Import your IO settings. This should get all your Aux's and effects on Aux's into your new session. Also use your plug in settings that you saved. Hope this helps. |
Splitting large sessions into smaller sessions | brandondurham | Tips & Tricks | 2 | 10-06-2013 09:02 AM |
Very large sessions | nosfoe | Pro Tools TDM Systems (Mac) | 15 | 12-11-2009 02:21 AM |
Handling large sessions when mixing.. advice?? | luts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-23-2007 02:12 PM |
Handling large sessions when mixing.. advice?? | luts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-22-2007 11:54 AM |
Large Sessions | ajazzie | Pro Tools TDM Systems (Mac) | 4 | 08-06-2002 05:46 AM |
