Old 07-01-2014, 06:30 AM
Jenre Jenre is offline
Default Automation not writing
Been having this problem for a while with different versions of PT and on different sessions, so i'm not sure if it's a bug or a particular setting I need to look at? If I select auto write and try and place some mutes in during playback it just will not write. I have to go back and draw it in. It's a real pain in the ass.
I've trashed preferences plenty of times between it first happening and now but it doesn't seem to help. It's hard to say when it does and doesn't happen as it seems to be completely random.
Old 07-01-2014, 09:38 AM
Craig F Craig F is offline
Default Re: Automation not writing
look at the Automation Window, Mutes are probably nu-sellected
Thank you,
Craig
Old 07-01-2014, 09:49 AM
I'm at work now so I can't check right now (obviously I will when I can) but I don't think it's only mutes this happens with. I only mention mutes as an example, and probably because 90% of my automation are mutes tbh
Thanks for the help, though. I will certainly check that out.
Old 07-01-2014, 10:05 AM
Mute is one function that might be easier to drop in with the mouse. Add a lane and select to view MUTE on that lane. With the line in the unmuted position, drag across a section you want muted, use the smart tool as the sideways bracket and drag the line to mute
Old 07-01-2014, 11:41 AM
Yeah I know how to draw mutes in, thanks. What I actually want is for Pro Tools to work properly.
Old 07-01-2014, 02:05 PM
I agree Maybe if you tell us what controller you use, and how you are entering your adjustments(maybe this is a hardware issue?), that might turn up more help
Old 07-02-2014, 05:48 AM
I'm literally just clicking mute on the channel with the mouse, no controllers.
Sometimes it works, sometimes it does nothing. It's just irritating more than anything - slows down your workflow.
Old 07-02-2014, 10:04 AM
Chapter 44, Automation Window, is Mute Automation Enabled or Disabled?
Thank you,
Craig
Automation writing on it's own cananball Post - Surround - Video 4 06-28-2014 11:36 AM
Writing Wah automation from GR5 tha]-[acksaw General Discussion 1 02-14-2014 11:44 AM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 02:41 PM
Writing Automation jcpro1 Tips & Tricks 1 03-31-2005 05:09 PM
Writing Automation In PT? peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-07-2002 04:09 PM
