MTC and Looping - PT as master to external sequencer?
Greetings,
I am trying to sync up Logic running on a separate machine to MTC generated from PT (5.1). It is partly working = when you hit play in PT, Logic starts from the right location, but if you are looping in PT, Logic does not jump back to the beginning of the loop, it just keeps on playing. Am I doing something wrong? Is this a problem with the MTC protocol, a bug in either of the programs or a switch that I have missed? Thanks, Jared |
Re: MTC and Looping - PT as master to external sequencer?
Due to the nature of SMPTE (as well as MTC), looping is not possible. It is an absolute measure of time that cannot loop back to a start point. If the time code was looped, it would cause glitches since a certain amount of pre-roll would be needed.
When trying to sync a sequencer with a loop in Pro Tools, you must also set the sequencer to loop at the same point. Otherwise it will simply keep playing. Brent |
Brent,
I have been told that this was something that was being done by Digidesign. Mark Gilbert of Gallery fame has led us to beleive that this was in the works development-wise... As far as MTC glitches, sure this feature would not need to be completely glitchfree at the loop points for the kind of work we do. Audio for picture. Just to be able to loop a section in Protools and have a videoplayer slave to incoming MTC. If it takes a second before playback resumes, so be it. It is a really important feature for this kind of thing.. I am not sure I see why this would be so hard to do and I have to admit that I am dissapointed as to your reply. Please re-consider. regards Janne Anderson |
Master MIDI clock to slave sequencer | Musepro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-24-2012 09:15 PM |
External sequencer master | phair | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-08-2008 02:31 AM |
Sequencer Midi connection looping Dilemna | Mason00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-25-2006 09:34 AM |
pro tools as master midi sequencer?? | romerom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-30-2005 01:11 AM |
Transfering note data from a sequencer to the sequencer of the digi 001 sequencer? | MichaelK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-05-2000 12:29 AM |
