Old 05-07-2015, 05:52 AM
Soul El Soul El is offline
Default Access Violation
Here I was just thinking to myself yesterday how rock solid PT was running there for about 6 months, then this happens.
Having a hard time figuring out exactly whats going on. In the middle of a session I had a completely random freeze, then out of the blue, this access code violation. So I exited the sesh, restarted, and then PT has another messege that it could not initialize the saffire. I unistalled PT, Saffire mix control, updated both and the problem remains. I've checked and win 7 audio settings and made sure every audio control program was on the same level. Trashed prefs and created a new sesh with a complete import of said track, just to see if the file was corrupt. Not sure what to do now. Any help would be appreciated. PT 11.3.1 Win 7 64bit Access code violation 0x0000000000000032 or something like that
SiSoftware Sandra
ID
Host Name : StewCPU
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS SABERTOOTH X79
Serial Number : 1403236********
BIOS : AMI (OEM) 4608 12/24/2013
Total Memory : 16GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz (6C 12T 3.9GHz, 3.9GHz IMC, 6x 256kB L2, 12MB L3)
Socket/Slot : FC LGA2011
Chipset
Memory Controller : ASUS Core (Ivy Bridge-E) DMI2 100MHz
Memory Controller : ASUS Core (Ivy Bridge-E) Integrated Memory Controller 0 Target Address/Thermal Registers 100MHz, 4x 3GB DIMM DDR3 1.33GHz 256-bit
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Patriot Memory PSD34G13332 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : VIZ E321ME
(1920x1080, 37.5")
Monitor/Panel : ACR Acer H203H
(1600x900, 26.4")
Monitor/Panel : Hewlett Packard HP w1707
(1440x900, 17.2")
Video Adapter : AMD Radeon R7 200 Series (14CU 896SP SM5.0 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit, PCIe 3.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon R7 200 Series (896SP 14C 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit)
Compute Shader Processor : AMD Radeon R7 200 Series (896SP 14C 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit)
Storage Devices
Samsung SSD 840 EVO 500GB (500.1GB, SATA600, SSD, SED) : 466GB (C:)
Samsung SSD 840 PRO Series (256GB, SATA300/600, SSD, SED) : 238GB (D:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA300/600, 3.5", 7200rpm) : 932GB (F:)
Samsung SSD 840 PRO Series (512.1GB, SATA300/600, SSD, SED) : 477GB (G:)
Seagate ST1500DL001-9VT15L (1.5TB, SATA300, 3.5", 5900rpm) : 1TB (H:)
CENTON DS Pro (4GB, USB) : 4GB (K:)
WIBU - CodeMeter-Stick (41.2MB, USB1) : 39MB (J:)
hp DVD A DH16AAL (SATA, DVD+-RW, CD-RW) : N/A (E:)
Logical Storage Devices
System Reserved : 100MB (NTFS, 4kB) @ Samsung SSD 840 EVO 500GB (500.1GB, SATA600, SSD, SED)
SSD 256 (D:) : 238GB (NTFS, 4kB) @ Samsung SSD 840 PRO Series (256GB, SATA300/600, SSD, SED)
Black (F:) : 932GB (NTFS, 4kB) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA300/600, 3.5", 7200rpm)
SSD 512 (G:) : 477GB (NTFS, 4kB) @ Samsung SSD 840 PRO Series (512.1GB, SATA300/600, SSD, SED)
1.5T (H:) : 1TB (NTFS, 4kB) @ Seagate ST1500DL001-9VT15L (1.5TB, SATA300, 3.5", 5900rpm)
CENTON USB (K:) : 4GB (FAT32, 4kB) @ CENTON DS Pro (4GB, USB)
CODEMETER (J:) : 39MB (FAT32, 512bytes) @ WIBU - CodeMeter-Stick (41.2MB, USB1)
Hard Disk (C:) : 466GB (NTFS, 4kB) @ Samsung SSD 840 EVO 500GB (500.1GB, SATA600, SSD, SED)
Optical Drive (E:) : N/A @ hp DVD A DH16AAL (SATA, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : ASUS Patsburg LPC Controller
Audio Device : ASUS Patsburg High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : MSI High Definition Audio Controller
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : ASUS Patsburg 6 Port SATA AHCI Controller
Disk Controller : ASUS Asmedia 106x SATA Controller
Disk Controller : ASUS 88SE9128 PCIe SATA 6 Gb/s RAID controller with HyperDuo
USB Controller 1 : ASUS Patsburg USB2 Enhanced Host Controller #2
USB Controller 2 : ASUS Patsburg USB2 Enhanced Host Controller #1
USB Controller 3 : ASUS ASM1042A USB 3.0 Host Controller
USB Controller 4 : ASUS ASM1042A USB 3.0 Host Controller
USB Controller 5 : ASUS ASM1042A USB 3.0 Host Controller
FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
SMBus/i2c Controller 2 : Intel SNB/IVB/HSW-E XMB Ch 0 SMBus
SMBus/i2c Controller 3 : Intel SNB/IVB/HSW-E XMB Ch 1 SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : CENTON DS Pro (3.73GB)
Network Services
Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Home Media Center 6.01.7601 Service Pack 1
Platform Compliance : x64
Old 05-07-2015, 06:34 AM
Default Re: Access Violation
Think I got it. Re located all plug ins to unused folder then replaced after starting the session. Windows re configured and it took awhile to restart but its a sign, its a plug in.
Old 05-07-2015, 07:30 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
From your Sandra report, I noticed that you have two different brands of memory installed. From what others have said here on the DUC, that could cause problems. Also, your H drive is only 5,900 rpm. If that is just used for backup, no problem, but shouldn't be used as an audio drive. But it looks like you have narrowed the issue down to plugins. If the error occurs again, remove all of the plugins and bring them back into the plugins folder a few at a time to find out which one(s) are the culprit. Most likely a third party plugin, not a stock Avid one.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 05-07-2015, 07:40 AM
sw rec sw rec is online now
I get these occasionally too, on 11.1.3 (Actually, EVERY version of 11 has done it.)
My workaround, and it works every time, is to open up TWO tracks when I record, and record on the second of the two. For some odd reason, that stops it from happening.
Old 05-08-2015, 04:44 AM
Both good suggestions, thx for the reply. Yeah the 5900 is just a storage drive, I would never lol. I need a few more 7200's cuz the 1.5T is somewhat corrupted or just slow as all hell for some reason. Not too worried about the Ram as of yet, if u have the processing power the Ram is a small step I would imagine, I'm sure it could run better, but it works like a champ for now.
access violation djra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-14-2007 12:39 PM
Access Violation Question Mark Pro Tools M-Powered (Win) 4 02-23-2006 12:21 AM
Access Violation Question Mark Pro Tools M-Powered (Win) 0 02-16-2006 10:23 AM
Access violation mellianojinksum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-19-2002 06:47 PM
access violation/access is denied dj_czech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-02-2001 12:37 AM
