Old 12-15-2012, 12:01 PM
nikydvt nikydvt is offline
Default Tempo operations window
Excuse my answer perhaps incongruous but I pray you to equally give me some explanation. I am trying to vary the tempo of an audio track from the Tempo operations window speeding up or slowing down the tempo values, but no audible result happen. The timebase selector of the track is on samples, elastic audio isn't in action; perhaps is this the error? but in Pro Tools Reference Guide there is no mention (in that chapter) to previously activate elastic audio. Thanks in advance. niky
Old 12-15-2012, 03:39 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Tempo operations window
What kind of audio are you trying to change? You could change your track to tick based and enable Elastic Audio and probably accomplish what you're trying to do.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-15-2012, 03:53 PM
soybalm soybalm is offline
If you slice up audio clips and change the tempo, and you have it sample based, the audio clips won't move. If you have it tick based, the clips will move but the content(wave) will stay the same. If you enable Elastic Audio, poly, mono, rhythmic, etc, everything will change.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 12-15-2012, 07:39 PM
cwsand's Avatar
Yes, and this method works well with drums and percussion for slight changes in tempo and can be done in conjunction with Beat Detective to automatically create crossfades between edited the clips. The drawback to using Elastic Audio, even using X-form, is that you're going to lose some sonic quality.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 12-16-2012, 08:42 AM
now all is clear, many thanks. nicky
advanced tempo operations help BillionsUponUs macOS 0 08-02-2012 01:20 AM
Event Operations window danander11 MIDI 7 02-08-2009 09:17 PM
MIDI Operations Window Doesn't Stay on Top erant1 Pro Tools TDM Systems (Mac) 1 12-07-2005 05:45 AM
Tempo Change Window bug shadowbox Pro Tools TDM Systems (Mac) 0 05-10-2004 09:09 PM
Make the MIDI Operations window 'floating' !! rme_uk Pro Tools TDM Systems (Mac) 4 07-20-2001 11:32 AM
