Editing Portamento in PT edit window?
How can I manually create a portamento slide from one note to another in a given time frame? I'd like to learn how to do this in the Pro Tools edit window rather than play it in real time and figure out how to program the Xpand!2 portamento to go at the correct speed (and, incidentally, the Xpand!2 synth doesn't even seem to have portamento functionality, even though it's a mono bass patch).
Basically, I want a synth bass note to swoop up from G to C in the course of an eighth note and I can't seem to make it happen.
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave. |
Re: Editing Portamento in PT edit window?
You could try pitch bend, but you might no be able to change it's range to more than 2 half steps.
Do you have the free version of sampletank? That has portamento Even Structure Free has portamento (glide) and control over the pitch bend range... It lists the glide rate as a percentage, so maybe that means as a percentage of a beat... If so then 50% should = 1/8 note, I guess
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Mix Window Freezes but Edit Window works fine. | wwicklund | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-10-2022 10:57 AM |
Sync Midi Window and Edit Window | teafan | Pro Tools M-Powered (Win) | 1 | 08-28-2011 03:36 PM |
Cannot change EDIT MODE in edit window | Xavior | Pro Tools M-Powered (Mac) | 2 | 05-24-2007 12:51 AM |
how to put transport window inside edit window? | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-18-2004 06:47 PM |
How do you scroll the window with the audio on edit window? | fsilano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2001 09:53 AM |
