HD setup help needed!
We have a Mac G5 and 192 with 16 ins, 8 outs. Works fine.
Now we just added a 2nd analog output card, and after that Pro Tools won't launch. We get this error: Quote:
And what needs to happen to get Pro Tools to launch and recognize our 16 outputs? |
Re: HD setup help needed!
Did you do what it said? Did you confirm the DigiLink cable was securely connected to the core card and the 192-I/O?
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Yes. Since the last post I came to the understanding (I think) that one slot in the 192 HAS to be used by the digital IO card. So we put that back in.
The end goal is to be able to route audio to and from some analog outboard gear. SO, we have 16 analog ins, 8 analog outs, and the digital IO card. Also, a ProControl board. So far we have not been able to get audio to hit any of the outboard gear no matter what we try. |
The 192 can only do 16/8 or 8/16. It can't do a 16/16.
You may want to look at Lynx or Apogee - they have a 16 I/O box.
... but does it help the chorus? |
So, with all this gear and "high end" Pro Tools system, we can't send to outboard gear?
You can, but you have to change your IO setup to do it, and only 16-channels at a time.
How?
There are a variety of ways.. Open that PT manual, and look for "hardware inserts" which is the most efficient way to do it. good luck, SB
Motu 828 setup help needed | SJDEMS | Getting Started | 16 | 03-29-2013 08:47 PM |
Advice needed on HD3 rig setup | audiogeekzine | Pro Tools TDM Systems (Mac) | 25 | 10-13-2009 08:28 PM |
What is needed for basic HD setup? | Kleekoh | Pro Tools TDM Systems (Mac) | 7 | 09-30-2004 04:00 PM |
I/O Setup for 001 Session needed for 002 | Wheate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2004 06:20 PM |
MIDI Setup Help Needed | stagegrin | MIDI | 3 | 08-05-2001 06:00 AM |
