Old 11-11-2021, 07:04 AM
JFreak JFreak is online now
Default Re: MacBook Pro M1 MAX - Pro Tools Performance?
Originally Posted by K Roche View Post
now how that reflect on the difference between Rosetta and Native I have no clue
For example, like... many users have reported that Kontakt crashes PT while trying to load first library, so for those users Kontakt VI track count is zero.
Old 11-11-2021, 07:07 AM
Chevron Chevron is offline
True he was not mixing, but I would think being able to record 400 audio tracks, all with two plugins ( apparently not CPU intensive plugins ) But still ,,,considering he was recording all that running @ 32 sample buffer, all at the same time, I would think that would amount to a pretty good amount of headroom for most mixing situations .. Now he did not record any VI's in the PT portion but he was playing back some 30 in the Logic portion with 90 audio and then later played back 200 VI tracks..... now how that reflect on the difference between Rosetta and Native I have no clue ...
Thanks for posting, and good to see the performance - but I do not think it is directly relevant to mixing with Pro Tools using stacks of 3rd party plugins under Rosetta 2....
My bad if I didn't directly say that.
Old 11-11-2021, 07:08 AM
But I did. Currently it is software that is limiting mixing possibilities and performance, not hardware.
Old 11-11-2021, 07:13 AM
Yup. What I am asking is direct experience from a user with an M1 MAX (OR PRO) MBP for heavy-duty mixing? So I can make an informed decision about buying such a machine for such a purpose.
To quote Fargo "If I am getting bank interest, I want complete security. Heck, FDIC. I don't see nothing like that here."
Old 11-11-2021, 07:14 AM
Why do you need PRO/MAX hardware to confirm that certain plugins behave badly or do not work at all?
Old 11-11-2021, 07:27 AM
You are overcomplicating this by guessing what I need, rather than what I am asking.
MBP M1 MAX with Pro Tools for mixing, what is the CPU % lost by running under Rosetta 2 vs native?
Old 11-11-2021, 07:43 AM
dominicperry dominicperry is online now
If you've got a session you want me to try, I can compare:
Mac Pro 7.1 16-core 48GB on 10.15.7
with
16" MBP M1 Max 10/32 with 64GB on 12.0.1
I have RME Babyface and Avid Carbon. PT Std and PT Ultimate
So far in my PT tests, they both run about the same, but something (probably Monterey) fouls up the Avid Complete Bundle plugins, and I've had to take them all out.
I'm using PT 2021.10 on both but can try 2021.3 or .7 if you prefer.
You can't calculate the loss of Rosetta vs Native for PT, because you can only run under Rosetta on M1. And you can only run as Intel native on Intel.
Logic (which is of course native on the M1 Max) runs about the same number of channels at minimum buffer size on both platforms.
Dominic
Old 11-11-2021, 07:44 AM
Yes, hopefully someone will answer you that once we have native PT software and native plugins. Currently it is not possible to answer that question.
My point was if you need badly behaving plugin, or one that crashes PT entirely, your system's real world performance sucks in mixing.
Old 11-11-2021, 07:45 AM
Originally Posted by dominicperry View Post
I can compare
Do you have native build of PT software and required plugins? That is the real question, performance on Rosetta vs Native.
Old 11-11-2021, 07:47 AM
As you say (and I've edited my post) - no one knows. It isn't possible to compare.
Macbook Pro 13" vs. iMac Pro |*Pro Tools Performance Meads macOS 0 11-14-2019 11:51 AM
MacBook Pro i9 throttling and performance Guitarman002 macOS 42 02-01-2019 11:20 AM
Macbook 12" + Pro Tools 11. What performance can I expect? tobbenos macOS 4 07-15-2017 04:21 PM
Performance of Macbook (Pro) rmccam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-19-2007 10:05 AM
macbook performance Bologma Pro Tools M-Powered (Mac) 12 04-16-2007 09:16 AM
