Old 07-04-2021, 06:53 AM
Sparky1 Sparky1 is offline
Default Carbon and CPU Spikes
Hi everyone.
I can’t seem to find the answer to this…
If I am currently experiencing CPU spikes and have done all the optimizations that are recommended… will the new Carbon interface help with this problem?
From what I’ve read so far is that it can help with offloading some of the work of RAM - but not been able to find a definite answer to the CPU issue…
Pro Tools 2020.12.0
MacBook Pro (Retina, 15-inch, Late 2013)
2.3 GHz Intel Core i7
16 GB 1600 MHz DDR3
Mojave
Thanks
Sparky
Old 07-04-2021, 10:13 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Carbon and CPU Spikes
Hi friend if i was you i would start looking at the cause of it and no for something that " can makeup it " ?
Remove all your plugins from the aax plugins folder and try PT without them. Carbon is great imo but i dont think it would really fix a current issue.
And last double check your OS optimizations and pay special attention to the automatic graphic switching that i think apllies to your mac. ( I may be wrong ).
Hope this helps
Avid Carbon Interface
Protools Ultimate
Old 07-04-2021, 11:46 AM
dominicperry dominicperry is online now
The problem is at least partly that each new version of Pro Tools takes more processing power just to get the wheels spinning. You're running a relatively old machine (2013 MBP) which just doesn't really have sufficient power beyond tracking and simple mixing.
The Carbon needs a recent version of PT to work (I think 2020.11 is the earliest). And it doesn't have a huge amount of DSP power - if I run 16 channels at 96KHz (which is effectively 8 analogue inputs and both ADATs running SMUX at 96KHz) then I can put the bx_console_N channel strip and the McDSP channel strip on 15 of them, and that's it. I'm out of DSP. Of course, there's no need to run two channel strips on each track - but instead I could put a chorus or an extra compressor, and then add a reverb or two to auxes. But there's not a lot spare at 96K.
At 48K there's a bit more headroom - I can run 24 bx_console_N strips - one for each channel with about 50% DSP spare. But my point is, there isn't a huge amount left over for a complex mix.
Dominic
Old 07-04-2021, 12:43 PM
Hope this helps
Greetings.
Thank you for the advice...
Should I have the automatic graphic switching on or off?
My current system has it unchecked...
Thanks,
Sparky
Old 07-04-2021, 12:48 PM
jeam25's Avatar
O would say off but check both ways . Who knows
Protools Ultimate
Old 07-04-2021, 12:51 PM
Yes - you are 100% in that my system is relatively old...
I was initially going to purchase one of the last remaining Intel MacBook Pro's with additional RAM - but am now second guessing my decision - as I think the future will most likely centre around the M1 chip
Doing a bit more research... it's starting to appear that my current MacBook Pro may not even be compatible with Carbon... which I understand because it is an older system
All this aside... do you think that Carbon will make tasks requiring CPU power easier?
Thanks,
Sparky
Old 07-04-2021, 01:02 PM
Thanks,
Sparky
I think waiting for an M1/M1X/M2 machine is a good idea.
Quite honestly, my guess is that running an AVB interface on an older Mac will be a disaster. It seems to cause a lot of processor overhead - which will probably result in your fans running the whole time. And your present machine is not on the list of approved machines, so it either can't run AVB at all, or it isn't powerful enough as far as Avid is concerned.
Dominic
Old 07-04-2021, 01:21 PM
Dominic
Yes... definitely leaning this way... I think I'll wait for an upgrade and just do the best I can for now...
Thank you for your insight...
Sparky
Old 07-04-2021, 07:57 PM
So… I’m still not certain what impact using Carbon - has on the CPU load specifically….
Sparky
Old 07-05-2021, 02:22 AM
Sparky
1) Running Carbon requires a recent version of MacOS and PT. Both generally require more CPU than earlier versions.
2) Running Carbon uses AVB, which puts a strain on the CPU which is not generally present with USB or thunderbolt interfaces, except at very low latencies.
3) Running Carbon moves plugin processing from the CPU to the Carbon ONLY for AAX-DSP plugs, and ONLY for tracks that are DSP enabled.
So, two things are probably worse for the CPU, one is better under certain circumstances.
FS: Protools Carbon Technog0d Buy & Sell 2 05-10-2021 10:25 AM
Carbon and Mac M1 / Big Sur and other ?’s darkwavo Pro Tools | Carbon 31 05-01-2021 12:57 PM
Carbon with anything other than 10.15.7? Matt Hepworth Pro Tools | Carbon 12 01-08-2021 07:14 AM
OS X Carbon error Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-26-2001 03:53 AM
