Audio Drive (Journaled)???
Hey All,
I see that DIGI now recommends that you format your audio drive to Mac OS Extended (Journaled). What benefits does this have as opposed to formatting the audio drive to Mac OS Extended. What are the pros and cons if any to having the audio drive Journaled? Thanks |
Re: Audio Drive (Journaled)???
Thanks,
Anyone else care to comment??? |
Anyone else Please???
Journaling increases the likelihood of the disk being usable after a bad system crash, and has a negligible performance cost.
Quad 2.5 G5, 4.5G RAM |
Meaning slightly slower disk performance?
Thanks |
As far as I understand the journalling keeps extra records when files are created and written (end of writing), which means slightly slower saving of sessions (possibly a few milliseconds per save) and creating fades.
When a session is already open and few files are being created - as in usual editing or mixing where the audio files already exist on disk - there should be neglibigle performance loss. When recording there might be a few milliseconds of extra disc work to write to the journal when you press record and when you press stop, but should be virtually no difference whilst recording is going since the new audio files have been created and disk space has been allocated. I'm sure there are apple Tech Notes about the performance of Journaling vs not. I think the general consensus is that the better data security with journaling is well worth the small performance hit. I expect that actual track playback counts on identical drives (one journaled, the other not) would be identical. |
Thanks Matt,
That was the type of answer I was looking for. And what I would expect in the Audio Drive Performance. This is funny because when I spoke to a DIGI Tech today, they claimed the Audio Drive would actually run faster! |
To add a bit to what Matt said, the system keeps a "journal" of every write action which includes an open, and finish category. This way, if your system crashes while writing data to the hard drive, the system can go back and look at the journal and essentially undo any unfinished commands, reverting your drive to it's pre existing state. An un journaled drive has the possibility of becoming unstable during a crash, say if it was during a write command to the directory etc... The amount of info written in the journal is very very small. I can't speak on performance of journaled vs. unjournaled details, except that I've never noticed a difference.
https://wanderingear.net |
If Digi wants Journaled, I wouldn't stray from that. The very small performance gain you'll achieve wouldn't be worth the increased instability and less likelyhood of a recovery after a crash. As far as I know, journaling is basically a handshake to confirm to the OS what actions are taking place and acknowledging them. Its essentially required for all Pro Tools version written for Tiger. I personally experience 7.0 crashing more often until I reformatted with Journaled ON. Then the issues disappeared.
But its always up to you. |
Used 'case sensitive journaled' drive for backup by accident. Problem? | Ru_C | Pro Tools TDM Systems (Mac) | 20 | 09-27-2011 11:34 AM |
HD journaled or no? | Floydio | Post - Surround - Video | 2 | 11-12-2009 10:12 AM |
Hard Drive Journaled HFS+ | joji | Pro Tools TDM Systems (Mac) | 4 | 03-06-2009 07:16 AM |
Journaled Drive | SteveGarman | Pro Tools TDM Systems (Mac) | 4 | 12-05-2006 01:47 AM |
Should the second drive be journaled? | cookachoo2002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-30-2004 09:32 AM |
