Problems using unitor 8 mk2 with 001 (OMS)
Has anyone else had problems with a Unitor 8 mk2 freezing up(Oms can't find Unitor 8 USB) in 001.I am using a G4 867mhz computer running OS 9.02.1 the unitor works fine then after a certain time(not always the same amount) oms doesnt see the unitor even though Pro-tools Le is still churning out Midi.I am using OMS 2.3.8(the one which comes with the Le installer)Its not the Unitor as when i use it in Logic with OMS switched off it works fine.Any Ideas i will be most grateful. TIm
Re: Problems using unitor 8 mk2 with 001 (OMS)
Make sure that you are using the latest versions of the USB Unitor Family System Extension as well as the Unitor 8 OMS driver. You can download these from Emagic's site at: http://www.emagic.de
Brent |
unitor | john1192 | Pro Tools TDM Systems (Mac) | 10 | 06-26-2003 01:03 PM |
unitor 8 | versatile | Pro Tools TDM Systems (Mac) | 1 | 01-11-2003 08:59 AM |
Annoying SYSEX Problems w/ Unitor 8 MKII | dparada78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-24-2002 07:30 AM |
New G4's and Unitor Midi Interface Problems? | legativity | Pro Tools TDM Systems (Mac) | 13 | 03-23-2002 07:46 PM |
unitor 8x8 usb | tantejo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-26-2000 11:38 AM |
