Old 11-08-2012, 02:26 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Pre and Post-Roll not working on D-Command
when I make a selection within the EditWindow and press play on D-Command, PT stops the PLB at the right edge of the selection though PostRoll is enabled.
When I hit the space-bar on the MacKeyboard, all works as expected and the post-roll amount will be played.
Question: Is it time to trash the PT-prefs again or is there a function setting at the D-Command which I might have enabled accidentally ?
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 11-08-2012, 02:32 PM
CHD CHD is offline
Default
I remember encountering this bug under PT8 or 9. Yes, the cure was to trash the prefs.
Dmitri A. Chernov
re-recording mixer/supervising sound editor/studio owner
Moscow, Russia
http://www.imdb.com/name/nm2555539/
Old 11-08-2012, 02:41 PM
Default Re: Pre and Post-Roll not working on D-Command
Thx a lot for the info ... sigh
Cheers, STeff
Old 11-08-2012, 06:39 PM
Just for the sake of completeness:
Trashed PT Prefs and set it up new (not taking a copy of my BackUp-Prefs file).
Pre & PostRoll are working okay again.
Cheers, STeff
Pre-Roll / Post-Roll - Not working! geelo Pro Tools 9 12 07-30-2016 12:02 PM
Pre-roll/post-roll appears to be broken in PT10 anodecathode macOS 1 02-20-2012 01:33 PM
Pre/Post Roll not working! products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2010 07:47 AM
Post Roll has stopped working??? The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2007 01:45 PM
Auto Input not working with post-roll bublabs Pro Tools TDM Systems (Mac) 0 08-02-2006 05:14 PM
