Patching in Hardware Inserts
Can anyone explain this to me simply. I'm having a huge time attempting to patch in my distressors for mixing.
Jon |
Re: Patching in Hardware Inserts
1. Assign your track's output to one of the hardware outputs on your interface, let's say output 8.
2. Patch interface output 8 to the input of the Distressor. 3. Patch the output of the Distressor to one of your interface inputs, let's say input 6. 4. Create an auxilliary input channel and set it's input to interface input 6. Use this channel to mix the output of the Distressor. Be aware that this introduces a delay of a few samples (the exact delay is given in the PT manual). It shouldn't be a problem unless you're combining the pre- and post- Distressor signals, in which case you'll need a delay-compensation strategy.
Dual 2.3 GHz PowerPC G5 2.5GB RAM OS 10.4.6 HD 2 Accel PT 7.1cs9 192 I/O |
Well shut my mouth. I can't believe I forgot about that. I think I've been in the box too long!
While Davip's description will work, it's not the method described in the manual nor is real good practice for an insert (unless you needed to take many tracks through one insert).
According to the manual, when you assign an insert, you can choose i/o for that physical insert. The i/o needs to match. So... if you send your insert from out 2, it needs to come in via out 2 as well. Then the insert will automatically bring in the insert. The method I mention above, keeps the insert pre-fader, like it's intended and doesn't use an additional aux input for play back. This will also keep in with the other inserts (i.e plugs). All else fails, read your manual... it's pretty clear in there. -t
http://SpeakRecords.COM |
tlester is right.. at the inserts where you normally insert a plug-in, below it is an I/O insert point.. select your I/O from the list. If you like, you can go into your I/O setup and label the I/O where you're connecting the distressor as Distr In and Out.
Rail
Hardware inserts | stanonbass | Pro Tools HDX & HD Native Systems (Mac) | 1 | 02-03-2014 06:13 PM |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Patching in compressor hardware latency issue | willl3 | Windows | 1 | 09-14-2011 07:36 AM |
002 Hardware Inserts | tele_player | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-26-2003 11:02 AM |
Hardware Inserts | danwestworld | Pro Tools TDM Systems (Mac) | 1 | 03-17-2003 10:42 AM |
