Regions/files are dissappearing!!!
I was working on session and wanted to implement some audio files from an old backed up session to the new one. I loaded in the old backed up session and did some editing chopping and pasting and even deleting some files in it. When I then started up my ongoing session it started to ask for missing audiofiles.
After some examination they turned out to have the same names as the one's that I have deleted in my backuped session. Are you not allowed to have the same names on audiofiles but in different sessions or??? I'm using PT 4.3.2, OS 8.6 on a beige G3/266 ------------------ Robert Uhlmann [This message has been edited by Robert U (edited August 02, 2000).]
www.extensivemusic.com |
Re: Regions/files are dissappearing!!!
Pro Tools tries to prevent "confused session" scenario by using a simple file hierarchy:
Session Folder --------->Session document ------------->Audio Files Folder ------------->Fade Files Folder As long as this file structure is retained, I was unable to reproduce the behavior you mention when working with sessions that contain identical filenames. I was however able to confuse one of the sessions when moving the 2nd session file into the folder containing the 1st session's Audio Files/Fade Files folder and trashing (from the Finder level) the 2nd session's audio files folder. Although I did not try importing audiofiles into a session referencing files of the same name, I can see how this could as cause problems (i.e. the Mac OS won't let you put to 2 files containing the same name in one location, regardless of creator type). Therefore, you need to make sure that you either retain the original file tree that Pro Tools creates or make sure that no two files contain the same name. I hope that wasn't too confusing. Brent |
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by Robert U:
I was working on session and wanted to implement some audio files from an old backed up session to the new one. I loaded in the old backed up session and did some editing chopping and pasting and even deleting some files in it. When I then started up my ongoing session it started to ask for missing audiofiles. After some examination they turned out to have the same names as the one's that I have deleted in my backuped session. Are you not allowed to have the same names on audiofiles but in different sessions or??? I'm using PT 4.3.2, OS 8.6 on a beige G3/266 <HR></BLOCKQUOTE> This is probably because the "ongoing session" remembered where the backed-up files were rather than the files you intended to be working with. You might try unmounting the back-up and then pointing Pro Tools at the first "missing" file (which isn't really missing, right?) Then Pro Tools should be able to find all the rest. ------------------ Paul Greyson Digidesign Engineering
Paul Greyson Digidesign Engineering |
files dissappearing | richard229 | Pro Tools SE and Essential (Win) | 2 | 03-31-2010 08:09 PM |
my music is dissappearing from sight! | strangelittleman | General Discussion | 2 | 04-12-2003 03:51 PM |
5.0.1 beta dissappearing regions | Whitecastle | Pro Tools TDM Systems (Mac) | 9 | 09-20-2000 05:17 PM |
5.0.1 dissappearing regions | Whitecastle | Pro Tools TDM Systems (Mac) | 3 | 09-14-2000 10:03 PM |
Dissappearing plug-ins! | Will Russell | Pro Tools TDM Systems (Mac) | 1 | 04-13-2000 01:35 PM |
