Help, routing internal mac audio to 001
How do you route the internal mac audio to the 001 outputs under OSX. In the old days you could do that in the Apple Sound Control Panel. I have installed the PT6.0LE upgrade and now cannot find the 001 in the Sound Control Panel.
Any help here very much appreciated! Thanks, Dennis |
Re: Help, routing internal mac audio to 001
Unfortunately you cannot route system sounds thru the 001 under OSX! There has been discussion about this here before, so search the DUC if you want to learn more about it...
The Burner |
maybe through the 1/8" ouput jack on sound card into the 001 inputs.
I'm doing that too,but the signal from the Mac is none too hot - and I hate giving up what used to be my main keyboard inputs!! [img]images/icons/frown.gif[/img] HH
thank guys! i am using inputs 3/4 to do that now. added an old aphex compressor that i stopped using (since plugins) to boost the gain.
also a bummer that the headphones do not work on "monitor mode" only the main monitor outs. thanks to all who helped!!! dennis |
Actually, u have to download the 6.0.1 update which has the drivers for that. once u installthen u can goto system preferences/ audio and BANG! there u will be able to use your 001 for internal audio
Mac out to 001 inputs 3/4. This allows you to go to monitor mode on the 001 for mac monitoring.
Hope this is helpful. |
Internal midi routing doesn't work | paulster | Windows | 14 | 08-14-2011 08:18 AM |
Internal Routing Bug? | oliarnalds | Pro Tools TDM Systems (Mac) | 9 | 09-07-2010 07:22 AM |
routing mac pro internal audio through pro tools | Mojosound | Pro Tools TDM Systems (Mac) | 8 | 08-28-2008 12:23 PM |
Alt SRC input internal routing on 002r | crazyfoo' | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2006 06:12 AM |
Routing to outboard or internal processor | ReniuR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2001 12:14 AM |
