Old 09-23-2007, 07:53 AM
variation variation is offline
Default Latency / Delay
I have just upgraded from an MBOX 2 to a Digi 002 everything is fine except when I try to record vocals. I set the buffer to 128 even 64 with Low Latency monitoring but still hear a delay when recording. I am using the headphone jack from the front of the Digi 002, I would need to hear the vocals in the headphones while recording. I know the fix for the MBOX 2 was to adjust the mix control and mute the track, is there any option or workaround for this with the Digi 002?
Old 09-24-2007, 09:29 AM
Default Re: Latency / Delay
can anyone advise or lead me in the right direction?
Old 09-24-2007, 09:36 AM
Phil Ogden Phil Ogden is offline
Yeah, the 002 does seem to be a step backwards where latency/monitoring is concerned. It might help if you lighten the load on the CPU as much as possible. Even overdub to a stereo stem in a new session and then import into your original session for mixing.
Otherwise, a small external mixer might be the way to go.
Old 09-24-2007, 03:11 PM
Picky ears I guess. I've been using 002(and now 003) for 3 years and never had a complaint or problem running 128 and/or using low latency monitoring(regardless of buffer setting) makes latency a non-issue for many of us users. Whatever step backwards you think this is, it is a giant step forward when it comes to overdubs and punching in.
Old 09-26-2007, 01:15 PM
thanks for the replies ... I dont think its picky ears because i also hear significant difference, i have also tried just with one track and still hear the latency ... anybody else experiencing this or can help out ... I hope i didnt make a mistake upgrading the 002 if this is how it operates.
Need Help, cannot record at all due to latency/delay gumbi Pro Tools 11 7 09-20-2014 12:56 PM
Delay/Latency? Cal D Pro Tools M-Powered (Win) 0 10-29-2011 10:40 AM
Plug-In Delay, Latency seagullsf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-14-2005 08:06 AM
Delay/Latency Compinsation Gordon -10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-13-2005 03:19 AM
Latency Delay While Recording thejewdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-11-2004 07:31 PM
