internal routing problem with REASON
Hello!
I´ve got a little problem with a routed audio signal that I want to record. I´ve created a "loop" through endless feedback in Reason and would like to record the audio of it, but the problem is that it requires MIDI data so that Reason´s sequencer plays back simultaneously when I press record. The message "waiting for MIDI" appears although I´ve routed the signal to another audiotrack. So what can I do to make PT avoid its hunger for MIDI data ? Thanks in advance, David |
Re: internal routing problem with REASON
Make sure that 'Wait for Note' is turned off in your Transport bar.
Hello!
Nope, dunno why but it still does not work as I wish although your suggestion sounds so reasonable - it doesn´t make reason-able to cut the link between the two sequencers..... Hmmh, no good for me... But thanks anyways! David |
Internal Routing Bug? | oliarnalds | Pro Tools TDM Systems (Mac) | 9 | 09-07-2010 07:22 AM |
routing mac pro internal audio through pro tools | Mojosound | Pro Tools TDM Systems (Mac) | 8 | 08-28-2008 12:23 PM |
Alt SRC input internal routing on 002r | crazyfoo' | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2006 06:12 AM |
Help, routing internal mac audio to 001 | hitp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-30-2003 12:44 AM |
Routing to outboard or internal processor | ReniuR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2001 12:14 AM |
