Nasty Pops From Plug-ins
Hey Guys,
I was experimenting with some compressor plugins on my master fader. I made sure the output going into the next plugin wasn't too hot as to avoid digital distoration. Even when I bounced with low levels, I still ended up with some nasty clicks and pops throughout the whole song. There's also some weird level drops - like the compressor is going in and out. And no, it's not the attack/release. I bumped the buffer up to 1024 (that's helped before) - but this time it didn't. Chain: T-Racks -> L2 -> RVerb -> Dither PT 6.7cs8, 002 Rack, Dual 1 GHz w/ a very clean system. Any ideas? |
Re: Nasty Pops From Plug-ins
Is the T-racks a demo? I know their demos put in click like noises until they are serialized.
--- Chris
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
T-Racks wiill definitely introduce pops on a demo (tried it) which is a bit dim, as you can't really tell if you want it or not. Most demo stuff is fully working but you can't save changes or user settings. For the same price, or less you could get the Waves Musicians II bundle, which has the Ren Comp, and EQ, and Vox, Delay and Doubler. It's Waves. and I promise you'll never use T-racks again.
Is this the blues I'm singing? ------------------------ G5 2.5dual, 4Gb Ram 2x250gb HDs. Using PTLE 6.9 under OS10.3.8. |
Thanks for the input guys, but I've purchased both T-Racks and Waves, so the problem isn't with demo clicks.
Any other ideas? These clicks are horrible. It's not in the audio itself - it's definitley something with the playback engine or plugins. |
My bundled T-Racks EQ mysteriously makes loud cracks and pops every now and then, especially if I instantiate the plug-in while playback. Try removing T-Racks to see if the noise continues to happen.
R. |
C- YA BBOY ____________ G4 Dual 867mhz 768mg ram 002 Rack 4 BAY REMOVABLE Firewire Drive 120 gigs per bay WAVES PLAT. & RESTORATION PLUGINS |
Clicks and Pops because of Waves Plug-Ins? | Simmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-29-2010 10:38 AM |
Pops and clicks with RTAS plug ins | toba | Pro Tools TDM Systems (Mac) | 21 | 10-25-2007 12:43 PM |
Pops and nasty noise with Altiverb 4 | spaceman | Pro Tools TDM Systems (Mac) | 14 | 05-06-2005 05:09 PM |
Nasty pops and cracks when applying plug-ins | WRX07 | General Discussion | 2 | 03-25-2005 05:31 AM |
Bounce to disk - yields nasty pops & clicks | Pindy | Tips & Tricks | 10 | 02-06-2002 08:30 PM |
