Old 11-14-2018, 10:21 AM
reichman's Avatar
reichman reichman is offline
Default Key command for clearing playlist solo?
68 pages of Pro Tools key commands, and the only way to clear a playlist solo is with the mouse? Really?
(I know I can switch to waveform view and that will clear the solo, but that's not a good workflow.)
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 02-04-2021, 10:06 AM
harleytat harleytat is offline
Default Re: Key command for clearing playlist solo?
I made a Keyboard Maestro macro that does just this. YMMV.
Old 02-04-2021, 01:02 PM
rhumphries rhumphries is offline
Doesn't Shift+s do what you want? It only works when the playlist is selected though, so maybe that's not what you want.
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 02-04-2021, 01:55 PM
Can't speak for Nathaniel, but what I wanted was to be able to clear a playlist solo with the keyboard no matter where the PT cursor happened to be.
Old 02-05-2021, 08:17 AM
Are you looking to clear a playlist solo while leaving other solos intact? If not, does the "Clear Solos" Eucon command not clear playlist solos too (I haven't actually checked)?
You do know that if the cursor is in the solo'd playlist (even though the playlist doesn't "highlight"), shift-s will clear the playlist solo?
http://www.richbreen.com
Old 02-05-2021, 08:56 AM
Can't speak for Nathaniel, but yes, aware of the shift-S shortcut and use it all the time. I kept finding myself, though, in the situation where the cursor would be back up on the main playlist while one of the many take playlists below was soloed. Hitting option-shift-S is much quicker than hunting down the soloed playlist, putting my cursor on it, then cancelling the solo with shift-S.
Old 02-21-2021, 05:04 PM
Heilos4 Heilos4 is offline
How well does this work? I'm looking for the same thing here. I hate using the mouse to click the small buttons
iMac (Retina 5K, 27-inch, Late 2015)
32 GB 1867 MHz DDR3
3.2 GHz Intel Core i5
High Sierra 10.13.6
ProTools 2019.12.0
Artist mix/Control
Axiom 48
G-Raid External Drive
...Nintendo Switch
Old 02-22-2021, 07:48 AM
Well! Any time you're using "found image" detection, there can be edge cases that get weird (especially if you're using multiple monitors, or going between a laptop screen and external monitor). I also subsequently added to this script to make it more robust for different track height views. Overall though, if you like fiddling with scripts, I highly recommend using KM to add functionality where you see fit.
Old 02-22-2021, 07:56 AM
Originally Posted by Rich Breen View Post
...does the "Clear Solos" Eucon command not clear playlist solos too (I haven't actually checked)?...
Just to confirm - this does *not* work. I would classify that as a bug; "Clear Solos" should do exactly that, clear all solos including playlist solos.
Old 02-26-2021, 10:45 AM
And just noticed this; playlist solos are not reflected by the main "solo" indicator in the main edit window toolbar and of course they are not "clear-able" by clicking on it. This really seems like it should be addressed.
HTML code is On
Latch Solo Playlist in Soloed Track Any Ideas? Nick Camaron Tips & Tricks 3 01-30-2020 10:56 AM
playlist solo intermittent in PT9? Fritz Pro Tools HDX & HD Native Systems (Mac) 1 04-06-2013 05:09 AM
playlist solo intermittent in PT9? Fritz macOS 0 03-29-2013 06:00 AM
Grouped Track Playlist solo shortcut??? Epik Productions Pro Tools TDM Systems (Mac) 2 07-25-2010 09:51 AM
clearing d command snapshot corym ICON & C|24 2 10-07-2008 12:55 PM
