Old 08-10-2020, 08:17 AM
rhumphries rhumphries is offline
Default Text Copy and paste bug, anyone else?
I've just put together a new system running PT 2020.05 on windows 10. and I've encountered a strange bug when copying and pasting text to a file name.
If I copy some text, like a spot name or ISCI code for example, and try to paste that to the start of a clip name by double clicking the clip, mousing to the start of the name and hitting ctrl v, the pasted text always goes to the end of the filename, not wherever the cursor is.
Anyone else seeing this?
This also seems to happen in other text fields, like the "batch clip rename" window. Location Markers, etc. It doesn't happen in other applications.
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 08-10-2020, 08:32 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Text Copy and paste bug, anyone else?
I believe PT thinks you always want to append something. Try putting your cursor somewhere in the text and then using the left arrow key to move the cursor to where you want to copy the text.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-10-2020, 08:48 AM
Thanks, but I've done that. No matter where the cursor is, it pastes to the end. Is anyone else seeing this behavior?
Edited to add a video of it happening.
https://www.dropbox.com/s/fc3j76udv5...ug%20.mov?dl=0
www.TakomaMedia.com
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
has paste text bug for import audio been fixed in 8.0.3 ? jeremyroberts Pro Tools TDM Systems (Mac) 1 01-31-2010 03:24 PM
Copy and Paste text problem ronwasserman Pro Tools TDM Systems (Mac) 4 10-06-2009 09:05 PM
Can't copy and paste text jimlongo Virtual Instruments 4 07-23-2007 11:54 AM
