#3201
Re: i7 Builds - Specs and Results
#3202
i have had my rig up to 4.6 GHz stable. i only brought it back down due to heat issues.
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
#3203
ok so i think im gonna go through cyberpowerpc. i think they are the cheapest even if you can't dive in to all the components you want.
i'll post the specs in a later post i dont want to build it myself b/c i dont have the patience to screw in the motherboard and connect all the lil parts. plus my hands are kinda big and i dont see that working for me lol. |
#3204
Im planning an x.58 Win 7 build using the Asus P6T m'board... 6 Gb ram Two graphics cards including the Gigabyte NVIDIA GTX470 and something fanless like ATI4650... both are PCI-e x16. I also need to fit a UAD2 Solo PCI x1 card..... There are more than enough PCI interfaces on the m'board to handle this. Is there any risk that there will not be enough physical space between the PCI interfaces on the motherboard to allow these three cards ? What if I later switch the cheap graphics card and install a second GTX470 ? (when 64bit Pro Tools is available). Or want to add a Pro Tools HD card? I read a review that warned about space issues hence my concern - though it may prove entirely baseless (?). Also, recommendations re. a 600/650 or a 700/750 power supply ? The CPU will be Intel i7 930 2.8 Ghz. There is a chance I could get a different cheap video card and run it in SLI mode with the GTX470 (but may not be worth benefits anyway?), otherwise its one card for Pro Tools and one for games. The cost diff between these PSUs isnt great so its more a question of whats best. Any other comments ? (Using a Antec P183 case). All appreciated. Any help for a imac user returning to the PC fold would be GREATLY appreciated. THANKS !!! |
#3205
I suggest that you do NOT mix video card brands in the same computer.
And about choosing brands, I had best results with ATI. In our HD systems the Nvidia drivers exibit IRQ conflicts with Digi cards. Switching to ATI was the solution. Right now, all out systems have 2 video cards of the same brand, (this is not Digi supported but works just fine) and some have different models for example: 4670+4550, GTS250+9500. No problems. R. |
#3206
Thanks for your comments Ricren - good suggestions I shall follow.
#3207
ok so after reading some more of the thread, and also doing someone online research, you guys are right building my own doesn't look all that difficult. ok so my questions are Rack case or standard pro and cons, aside from noise and heat. haha maybe those are the real cons of a rack. i'd love to mount my comptuer, i seen the rack case guitardom was using, is there any other highly recommended rack cases? As far as standard, i wouldn't mind if a rack option wasnt avalible, i know i'd get carried away with stupid mod's like lights and other dumb waste of money tempting guy stuff. does anyone have a rack with a working asus board in it?
#3208
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#3209
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#3210
rack size is easier to work with and many options for mounting it and where to put it. this is the problem as well. i would like a 3bay removable drive system in mine, but it will not fit, so i could only put a single removable drive in it. mine fits 4 hard drives and 3-5.25 bays in it. have to take this in consideration if it will work for you. but a standard atxnsize mb which the gigabyte and asus both are fit fine.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
