Lock Audio Regions to Bars/beats!!!!
Hey what gives?
PTs does not give the option to lock the audio regions to Bars and Beats. This really becomes a problem when you are using drums hits and stuff cut up in a track, and you need to change the tempo. my suggestion would be to either: a: make a preference to lock audio regions to either SMPTE position, or to Bars/beats. or B: Have a locking tool to lock regions to Bars/beats. This is a MAJOR disadvantage when 'programming' in PT. Please Digi...sort this one out! Ramesh. |
Re: Lock Audio Regions to Bars/beats!!!!
Some one back me up here!!
Hey mesh!
YES YES YES!! Need this one very much. (This is the ONLY way Logic works, which can also be a PITA when you need regions to NOT lock) It'd be great to have a lock for each region--just put a 'lock' and 'unlock' icon in the top bit of the edit window, so you can cmd-A then click 'lock' and you'd be sorted. marc |
Peter
http://www.merlinsound.de |
Peter: was that a question, or are you saying that it IS possible to lock regions to SMPTE???? If so, then how?
thanks, marc |
I was talking about Logic (Audio Platinum).
Yes, it´s no problem there - just select all the regions you want and select "lock/unlock regions to SMPTE" from the Arrange window submenu (AFAIR "object"). Peter
Bars and Beats | GTTTT | Pro Tools 10 | 4 | 04-05-2013 04:51 AM |
Getting the bars/beats lined up with an audio track tempo? | Bill0287 | Pro Tools M-Powered (Win) | 1 | 01-20-2011 06:36 PM |
Is it possible to zero out Bars and Beats? | jordan23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-23-2004 09:55 AM |
bars and beats.....its off | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-03-2003 01:47 PM |
Seperate audio regions into bars | bhuman77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-12-2002 11:40 AM |
