Digi 002 Main Outs vs. Monitors, which do you use?
Hey All,
Which do YOU use to monitor/mix sessions and why? I've been using my monitor outs into a power amp--to passive speakers but accidently plugged into the main outs a couple weeks back and wow, whatta difference in volume/presence. I'm back to using my monitor outs but wondered...what are the intended uses of both the monitor and mains? J.D |
Re: Digi 002 Main Outs vs. Monitors, which do you use?
Anyone?
The Outputs are mirrored.
I use my main monitors on my Monitor outs as it has the handy Volume knob on the interface. I use the Outputs 1+2 to my ref monitors which i turn on when i want to hear what a mix or production sounds like on smaller speakers. This output can also be used to send to outboard gear if the other 6 are used, just take care. |
The monitor outs and the spdif out go to my Central Station, and the main outs with the 6 other analog outs I use to route outboard stuff.
You know what I wish, was that the main outs and monitor outs weren't mirrored, it would be way more flexible for routing signal IMO. Specifically I wish solo would go to just the monitor outs, and not have the main outs switch over to solo, like a console can. Does anyone know of a way to configure this???
https://www.thirdeyerecording.com/ |
Hi there; have the same question which I still don't find completely answered. had my passive monitors plugged to the Digi002 MON outputs; just got a pair of active monitors; can I plug them to the Digi002 Main Outputs and get the same result in terms of sound quality? I wanted to compare sound of my pasive and active monitors. thanks in advance!
Eleven Rack Main Outs to PA amp and Powered Stage Monitors | AvidEditor | Eleven Rack | 17 | 01-29-2012 12:27 PM |
Problem with 002 main outs as well as head phone outs? | wiseal1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-10-2009 11:36 AM |
RCA cables and Digi 001 main outs | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-12-2007 08:11 PM |
Digi 002 Monitor and Main outs- the deal? | toddbux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-22-2007 05:16 AM |
DIGI 002r- ADAT outs for main DA monitoring.... | Bhennies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-02-2004 01:31 PM |
