WOW! new TC product
http://www.tcworks.de/home/content/e...ome/render_top
TC POWERCORe w/out the pci card. pretty cool. I hope the tc helicon plugin goes tdm. |
Re: WOW! new TC product
I'm curious to learn more abou this as TC will be in-house next week to show me a new product, this must be it.... awaiting to see it!
Hey Brad, could you ask them if their helicon plugin will developed for protools?
thanks |
heres a thought, I read this in the tc forum."
1/31/2002 "Question I would like to run POWERCORE and ProTools plug-ins at the same time. Can I do that? Answer Yes, it is quite easy to run POWERCORE and ProTools TDM in the same session, and the two work very well together. There are just a few considerations to make when setting up such a system. As POWERCORE and TDM plug-ins are inherently different, a host application that can address both the VST and TDM Plug-Ins is required. To accomplish this, you will need a TC PowerCore, a Digidesign ProTools Mix system, and Emagic's Logic Audio and ESB TDM Bridge. (Logic 4.73 or higher is recommended. Logic 5.0 is still being tested. ProTools HD has not been tested.) The procedure is to set up the Audio Driver Preferences to "Direct TDM" and "ASIO." (Do not select DirectIO.) On Aux channels where you insert an ESB Plug-In, you can use TDM plug-ins. In your "normal" audio channels (ASIO), you are free to use POWERCORE plug-ins." Now that this puppy is firewire, I wouldn't mind sticking a few extra in my rack running in tandem with and hd system. Only thing that worries me is the latency issues. |
ti probably won't be that much cheaper than an HD process card. It's a full rack space so it's not all that portable. as has already been proven the weakness in a native system is not the 3 of plugin's it can handle, it's the latency induced by the host processor having to do all the audio engine and mixing duties. all these extra pci (and now firwire) dsp cores do is add plugins but they dont address the core latency issue.
your latency argument just does not apply anymore. with current hardware and systems.... please find another gripe we currently use both ptmix and native system and report that pt rig is more latent than my native system running the lynxtwo cards... your beef may have been valid several years back but it just does not apply today.... i smell coffee brewing not sure if you read the specs on the diceII chip that is in the powercore.... if not take a look, it is very interesting. do your research before you spout out with the same rederic. your friend. capybara |
I think this looks great, particularly for adding to a laptop. However, I too am concerned about latency. Is my concern misplaced or would there be more latency introduced through firewire than via a PCI bus?
It just seems to me that it would take more time for audio to travel over Firewire for processing and back to the computer than it would via a PCI card snuggled into a slot. Hopefully I'm wrong. -MattiMattMatt |
I have recently read that latency over Firewire should not be an issue, unfortunately I cannot remember where. The Firewire bus is well designed and intelligent and needs little overhead and creates little latency. PCI is a really old technology and it won't be long for other technologies like PCI Xpress to kill it. Firewire will replace low end PCI usage the way ATA is replacing low end SCSI usage.
Its best to ignore opinionated nonsense such as "has already been proven the weakness in a native system is not the 3 of plugin's it can handle, it's the latency induced by the host processor having to do all the audio engine and mixing duties" Leave that style for the Cubase forum .....
Stuff, mostly |
your latency argument just does not apply anymore. with current hardware and systems.... please find another gripe we currently use both ptmix and native system and report that pt rig is more latent than my native system running the lynxtwo cards... your beef may have been valid several years back but it just does not apply today.... i smell coffee brewing not sure if you read the specs on the diceII chip that is in the powercore.... if not take a look, it is very interesting. do your research before you spout out with the same rederic. your friend. capybara <hr /></blockquote><font size="2" face="Verdana, Arial">Read the specs read the specs. I listen to the results and I know along with the other professionals on this list. Why don't you go back to the recpit with the other haters and watch as steinberg hits the dust in another year. |
your latency argument just does not apply anymore. with current hardware and systems.... please find another gripe we currently use both ptmix and native system and report that pt rig is more latent than my native system running the lynxtwo cards... your beef may have been valid several years back but it just does not apply today.... i smell coffee brewing not sure if you read the specs on the diceII chip that is in the powercore.... if not take a look, it is very interesting. do your research before you spout out with the same rederic. your friend. capybara <hr /></blockquote><font size="2" face="Verdana, Arial">Rederic, The firewire bus is inherently latent. Just imagining the stages and conversions of the audio path of this system gives me the shivers. I run PT TDM and PT LE and I'm forced to report that the LE systems have much more latency. [img]images/icons/wink.gif[/img] |
Product help | sbh9 | Pro Tools 10 | 5 | 02-12-2012 08:14 AM |
Where do I get my account with product info if registered a boxed product? | lanstrad | Pro Tools 9 | 3 | 08-30-2011 09:36 PM |
New Product 96k | KeithFinch | VENUE Live Sound Systems | 2 | 06-04-2011 07:36 AM |
A New Product!!!!!!!!!! | Bill Rigby | Post - Surround - Video | 35 | 05-23-2008 02:51 PM |
New Mac product! | homerg | Pro Tools TDM Systems (Mac) | 14 | 05-04-2002 08:36 AM |
