Old 07-07-2013, 12:35 PM
shanemorales's Avatar
shanemorales shanemorales is offline
Default OS X 10.8.4 safe with ProTools 10.3.5?
Just want to make sure before I update...
Old 07-07-2013, 02:14 PM
Southsidemusic's Avatar
Default Re: OS X 10.8.4 safe with ProTools 10.3.5?
Works great here
Both 10.3.5 and 10.3.6 with OSX 10.8.4
Just be aware that 10.8.4 is NOT yet supported by Avid, however doesn't mean it doesn't work.
Best
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-07-2013, 06:39 PM
oldgitguy's Avatar
oldgitguy oldgitguy is offline
Works for me:
iMac 27" 3.4Ghz i7, 32Gb RAM, 3Tb Fusion Drive for OS, PT10.36 and PT11.
OS X 10.8.4
Using an Anker USB3 powered Hub.
iLock2 key into hub.
Superdrive into hub.
Eleven Rack into USB port on iMac.
Using a Seagate Thunderbolt 4Tb External Drive for recording
with three partitions.
Thunderbolt to FW800 adapter to additional ext 2Tb HD for data.
Bluetooth enabled for my mouse and keyboard.
MOTU Micro Express for MIDI connected to Motif ES8.
Old 07-08-2013, 02:14 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Works here.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-08-2013, 05:49 PM
monsteroflove monsteroflove is offline
Worked for me. I'm running PTLE 10.3.6 on OSC 10.8.4, using a Digi002 Rack.
Hope that this is helpful.
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
Unable to work on Protools LE 8 with attached LaCie Rugged Safe Portable Drive ashishv_26 Storage Subsystems 6 02-23-2012 10:44 AM
Accelerating Protools - MBOX2 in Safe Mode RFF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-28-2009 01:15 PM
Safe to upgrade to 10.4.3 for Protools LE 6.9.2? Reesho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2005 07:50 AM
Is it safe to use a G4 500 yet? cander General Discussion 3 10-03-2000 09:18 PM
