slight pops and clicks when recording
Still pretty new to PT. While recording an ultra simple session, I am getting steady pops and clicks...here is what I did:
Create a new session at 44kHz, 24bit, wav Import an mp3 into a stereo audio track as a source to follow Create 1 mono audio track for guitar, add one instance of eleven free. When I record enable the guitar track and play alone, it's fine When I record enable the guitar track and play along with the source track, it pops and clicks; very slight, be very noticeable, and it gets recorded. Nothing is clipping RTAS is steady at 19% Disk never gets above 1-3% 256 samples, 4 processors, 90% CPU, DAE level 1 normal I am recording to an ext FW drive, PT 8.0.1 on WinXP SP3. Any ideas why this would be happening...I didn't notice it with 7.4. Thanks Bill Sandra-------------------------------------------------- Computer Model : Dell Inspiron 537 Processor Model : Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed : 2.33GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : Dell 0U880P BIOS : Dell A03 07/23/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR2 Chipset Model : Dell G41 DRAM Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Elpida EBE21UE8AFFA-8G-F 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Elpida EBE21UE8AFFA-8G-F 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : ATI Radeon HD 4300/4500 Series (40 SP 600MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4300/4500 Series (40SP 2C 600MHz, 512MB 400MHz) Storage Devices SAMSUNG HD502IJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) WDC WD10EAVS-32D7B1 (1TB, FireWire/1394/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache) : 932GB (K:) (M:) (P:) TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 466GB (NTFS) @ SAMSUNG HD502IJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) DATA (K:) : 244GB (NTFS) @ WDC WD10EAVS-32D7B1 (1TB, FireWire/1394/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache) MUSIC (M:) : 195GB (NTFS) @ WDC WD10EAVS-32D7B1 (1TB, FireWire/1394/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache) PRO TOOLS (P:) : 195GB (NTFS) @ WDC WD10EAVS-32D7B1 (1TB, FireWire/1394/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache) Optical Drive (D:) : N/A @ TSSTcorp DVD+/-RW TS-H653G (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : T0 87-18h Audio Device : Dell 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semiconductor Realtek 662 High Definition Audio Audio Device : Dell RV730XT Audio device [Radeon HD 4670] Audio Codec : ATI (AMD) AA01h Disk Controller : Dell 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 2 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 3 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 4 : Dell 82801G (ICH7) USB Universal Host Controller USB Controller 5 : Dell 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Dell FW322/323 IEEE1394 OHCI FireWire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Nitro PDF Driver (600x600, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft Office Document Image Writer Driver (200x200) Printer : HP Photosmart C3100 series (1200x1200, USB, Colour) Network Services Network Adapter : Realtek RTL8102E/RTL8103E Family PCI-E Fast Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Re: slight pops and clicks when recording
Do you have your internet connection running in the background (Wifi). And a firewall/virus-scanner too.
www.dragonmusic.nl |
There is a wireless router near the machine (but the machine is connected to the router via cable, not wireless), and anti-virus is also running on it. Never noticed a problem like this with 7.4 though.
UPDATE: I did a quick test with little old REAPER, and there are no pops and clicks...so it's not the guitar, the interface, or the computer per se...it's PT and how it operates. |
Right, one of the operating anomalies of Pro Tools is that it prefers to work alone. No A/V, no internet (especially wireless), minimum background applications running. Dell computer are especially troublesome with all the bloat-ware that comes installed. A new OS installation and new Firewire controller are usually required to get maximum performance from PT.
Also your audio drive is only 5400 RPM with only 8MB of cache. This is below minimum specs for PT.
I tried this again with reaper and found the clicking still present... could someone listen this short clip of a dry guitar and hear the clicks and tell me if this sounds like a HD speed issue or something else.... the clicks are very slight, but you can hear them
http://rapidshare.com/files/39596991..._0932.wav.html |
If you need to be connected to the web (which I do sometimes for downloads -- no wireless for me), you will need an anti-virus, anti-spyware program. Sorry. This is necessary. There are two AV programs I can recommend that Pro Tools seems to work fine with -- the reason is that these are not "viruses" themselves like McAfee and Symantec. The two programs are:
* Vipre from Sunbelt Software http://www.sunbeltsoftware.com/ and * Eset available at Walmart. Eset AV unfortunately needs something like Spybot S&D, which I found conflicts with PT and Teatimer.exe. So I'll stick with Vipre. I've informed Digi tech support of this, but I don't think they can make any endorsement especially since stuff changes when companies buy up their superior competition. I use Vipre. I've even been working in PT and this thing kicked on a scan and went through without event. It is not invasive in system files. It uses very little processor capacity. It's like the scan runs in the background. Also use Firefox as your default browser. You'll pick up less spyware. You need a minimum 7200 RPM SATA drive for your System Drive AND a 7200 RPM SATA drive for your DATA drive (or an external Firewire Drive -- no USB drives) -- note that with Firewire cards with Windows OS that Digidesign only supports certain ones. So if you're going to go that route, I'd contact tech support first and get the part numbers.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Pops and clicks the whole way through recording | radioheaded | Pro Tools 9 | 8 | 03-03-2011 03:08 PM |
Pops and clicks when recording in 7.3 | bunderson | Pro Tools M-Powered (Win) | 13 | 02-29-2008 07:57 PM |
Mbox "clicks/pops" during recording | Brubacher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-06-2004 05:54 AM |
Recording Pops and clicks on Mbox | Shizznik_McRuube | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-05-2003 05:43 PM |
Pops and clicks while recording | PAUL ALLEN | General Discussion | 4 | 09-28-2003 10:09 PM |
