Old 04-15-2012, 04:15 PM
stentor stentor is offline
Default Unable to use time compression tool or audiosuite gain.
Getting an error message that says "No record volumes designated".
Able to record onto a track though.
Workspace has my external hard drive listed R under both the A and V columns.
This session came from another studio, that may have something to do with it.
I am running:
PT 10.0.1
Digi 003
MacBook Pro OSX 10.7.3
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro8,2
Processor Name: Intel Core i7
Processor Speed: 2 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 4 GB
Boot ROM Version: MBP81.0047.B24
SMC Version (system): 1.69f3
Old 04-15-2012, 05:10 PM
Dism Dism is offline
Default Re: Unable to use time compression tool or audiosuite gain.
Is it only those two plugins that give problems?
As a general rule, whenever I get a session from another studio, the first thing I do is Import Session Data into a new session. This tends to prevent any little quirks that might come along with a foreign session, like screwy window settings or I/O dramas. Give it a go, see if it helps.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 04-16-2012, 03:04 PM
Do either one of those act as plug-ins? One is a tool and the other is part of a drop down menu.
Not sure if it makes any difference.
I can record audio fine, my disc allocation seems to be correct.
I just can't time stretch a region or adjust it's gain.
Old 04-16-2012, 03:30 PM
Both of them are indeed plugins (as they appear in your Plug-ins folder).
Have you tried ISD into a new session as I suggested?
D
Old 04-16-2012, 03:54 PM
Also, both tools are basically obsolete in PT10, since Clip Gain and EA are far simpler and faster to use.
D
Old 04-17-2012, 12:48 AM
I ended up having to start a new session and import session data track by track.
Thanks for the help!
Is there a Time compression expansion tool for midi tracks? PMTrub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-03-2007 05:51 PM
time compression tool not working properly john1192 Post - Surround - Video 2 07-06-2006 12:32 PM
Time Compression and Expansion Tool tlep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-25-2005 10:56 PM
Time Compression Tool jlonigro Post - Surround - Video 6 10-09-2003 10:38 AM
Time Compression Expansion Tool StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-25-2003 01:19 AM
