Old 08-05-2021, 02:23 PM
djgwk djgwk is offline
Default 2021.6/7 MacOS: Edit Window: Zoom Toggle breaks basic Track display elements
In Edit Window, when using Zoom Toggle, toggling to a different track than the one selected when Zoom Toggle is first engaged causes the following Basic UI elements to disappear:
Track name
Record
Input Monitor (on PTU)
Solo
Mute
Display type toggle and automation controls, and track drop-down menu, are not affected.
If enabled, Volume and Pan indicators in the I/O UI panel will also disappear, i.e. blank panels are drawn with no text inside.
I/O Input and Output selections are still displayed correctly.
This occurs across multiple tracks, i.e. if you engage Zoom Toggle on track 1 and then select track 4, UI elements for tracks 2, 3 and 4 will disappear.
This behavior occurs slightly differently in reverse: if track 8 is selected, Zoom Toggle is engaged, and then track 1 is selected, tracks 2-7 UI elements disappear... but tracks 1 and 8 will display as expected.
Attachment shows this behavior across multiple tracks.
Disabling Zoom Toggle, or selecting the original track where Zoom Toggle was engaged, restores all missing UI elements, so I'm guessing this is just some type of UI window draw error.
First noticed this in 2021.6, hoped it would be fixed in 2021.7 but was not.
PTU 2021.7 on MacOS Big Sur 11.5.1, iMac 18,3 i7 4.2, HD Native TB+Omni
File Type: jpg Screen Shot 2021-08-05 at 5.10.23 PM.jpg (25.7 KB, 0 views)
Old 08-05-2021, 06:41 PM
Ben Jenssen's Avatar
Default Re: 2021.6/7 MacOS: Edit Window: Zoom Toggle breaks basic Track display elements
Shocking!
Old 10-28-2021, 10:18 AM
Fixed in 2021.10
Display Breaks on Track Color Not Working Ellis Beckwith Avid S1, S3, Dock and Control App 4 02-13-2020 12:45 PM
Edit/Mix Window Toggle not working adamclairmont macOS 14 12-24-2018 09:48 PM
Toggle Edit/Mix Window on PC eddiejag Pro Tools 2018 3 11-07-2018 09:31 PM
toggle mix and edit window shortcut daven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-02-2005 02:02 PM
toggle edit/mix window rogga_bogga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-01-2003 02:46 PM
