002 line inputs 1-4
Hi, sorry if i've missed this somewhere else.
Is it possible to set inputs 1-4 on a 002 rack for line input +4? I'm going from a desk into 1-4 using balanced 1/4 inch jacks and am getting heaps of distortion even though set to line. no probs with 5-8 using the same setup and set to +4. cheers, Matt |
Re: 002 line inputs 1-4
If you stick a 1/4" through inputs 1-4 they 'are' going through the pre-amps and those pre-amps aren't that good.
PT 9.0.3 Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's ....and a couple other toys. |
The specs are on this page:
002 They have the same listed "max input levels" but they do have different specs, including dynamic range, presumably because of the preamps. You are using them with the line/mic switches set to line, right?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Yeah, they're set to line with the gain down as far as it will go but they distort. Is there a way to bypass the gain on inputs
there's no way to bypass the pre-amp of those inputs, even with the LINE switch toggled.
It's really annoying, I had the same problem. I use 5-8 for the LINE inputs and occasionally 1-4 for mic inputs - but, as you probably know, they're not that good. Only other option I can think of, is to perhaps purchase another unit that can connect via the ADAT input. Lemme know if you find/think of another way!
View my website: James Arter Music www.jamesarter.com Soundcloud http://www.soundcloud.com/happybunnyproductions |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
Mic/Line and Line inputs on Mbox2 Pro | DAT11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-16-2007 08:06 PM |
001 vs. 002 in mic line inputs? | gonglee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-19-2004 05:24 AM |
Pre on line inputs 1-4 | drenched | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-22-2003 05:38 AM |
should i record into the mic or line inputs? | cane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-03-2001 07:37 AM |
