Old 09-21-2022, 05:55 PM
unkJE's Avatar
unkJE unkJE is offline
Default Spectrasonics free update - Flow Capture™
This FREE UPDATE for all Spectrasonics Keyscape, Trilian and Omnisphere 2 users is available now.
Press the "Check for Updates" button on the splash screen to get it!
https://youtu.be/Kj0w7FhbcWA
https://www.spectrasonics.net/news/n...ent.php?id=137
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 09-21-2022, 07:14 PM
unkJE's Avatar
Default Re: Spectrasonics free update - Flow Capture™
After your download completes, please locate and unzip the 'Spectrasonics Updater.zip' file.
The following components will be included in your download:
Keyscape Software 1.3.3d
Omnisphere Software 2.8.4d
Trilian Software 1.6.3d
Release Notes:
Omnisphere Software 2.8.4d (Version History)
Includes the following features and fixes:
• Flow Capture: New Standalone recording function that allows you to grab spontaneous musical moments as audio, MIDI and sound formats simultaneously
• Adds Metronome and Tap Tempo to the Standalone host
• Fixes an issue in Logic 10.7.4 where loading an AU preset file did not update the AU preset name at the top of Logic's plugin window
• Fixes a bug where sending the plugin Pitch Bend sequences that contain a wide range could cause audible stepping at large Host buffer sizes
• Fixes an issue with Sound Lock where locking the Arpeggiator and changing patches caused the Arpeggiator preset name to get reset
• Fixes a bug where the mini-browser could become stuck on top after a "Paste Layer" action in the Soundsource browser
• Mac installer: Updates ReadMe files and the HELP button URL
Trilian Software 1.6.3d (Version History)
• Mac installers: Updates ReadMe files and the HELP button URL
Keyscape Software 1.3.3d (Version History)
• Fixes host automation issues with Logic Pro 10.7.3 on Intel Macs (or M1 Macs running Logic Pro via Rosetta translation).
• Fixes Logic Pro automation ID sorting issue on M1 Macs (Apple Silicon)
• Fixes issue where the Scales menu on the Settings tab was unresponsive
• Fixes potential issues with selecting entries in popup menus
• VST3: Fixes issue where patch info and background graphics did not update after loading a patch
• VST3: Fixes issue in Cubase where the Camera icon and Quick Controls button were not displayed in Cubase's plugin header
• VST3: Fixes issue on Windows where "Get Updates" button did not link to the Smart Update webpage
• Fixes graphics performance issues on macOS Monterey.
• Fixes issue where the "Realism" control in Factory patches could freeze the GUI temporarily.
• Fixes crash that could occur when a Soundsource started playing for the first time.
• Fixes issue where switching patches could cause audio glitches.
• Fixes issue where setting polyphony (# voices) to 64 could cause the plugin to stop responding to Note On events.
• Windows only: Fixes issue where playing MIDI notes while a Soundsource is loading could cause CPU spikes and audio glitches.
• Windows only: Fixes issue where playing a Soundsource with Thinning enabled could cause CPU spikes and audio glitches.
• VST3: Fixes issue where "Enter Value" feature for manually typing in automation values did not work
• VST3: Fixes issue where host automation values changed after closing/ opening the GUI
• VST3: Fixes issue where VST3 Hosts added a resizing handle to the VST3 plugin GUI
• VST3: Fixes issue where changing the Clock Speed parameter did not work properly
• VST3: Fixes issue where creating new parameter automation assignments did not work in REAPER and Bitwig Studio
• macOS Installer updated to run natively on M1 Mac (Rosetta 2 not required)
• Windows Standalone app updated to v1.1.0d. Resolves Windows system DLL loading issue
• Adds native support for Apple Silicon M1 Macs
• Adds VST3 plugin version
• Improves parameter names for host automation. Adds space between part number and param name e.g. "8Amount" -> "8 Amount"
• Fixes crash related to clicking on patch in browser while MIDI-CC learning is in progress
• Fixes issue where the first note played after loading a DAW project sometimes produced silent or corrupted audio
• Fixes issue where delay effects trails with a duration greater than 20 seconds were muted.
• Fixes issue where knob graphics could fail to render on computers with older graphics cards.
• Fixes standalone GUI scaling issues on Windows 10
• Fixes GUI performance issues on macOS Big Sur
• Fixes issue where changing Patches or Multis could crash certain DAWs on Windows 10
• Fixes issue where the MIDI icon did not appear next to the patch name after assigning a new Browser learn
• Fixes issue where the Unlearn function did not work for Browser learns
• Fixes issue where Browser learns did not restore from saved MIDI Template files
• High-resolution Interface
• macOS Big Sur Compatible
• Improved authorization process
• New Audition Auto-Play feature enhancements
• Fixes GUI performance issues on macOS 10.14 and later
• Fixes issue where audio could glitch when two DAW tracks contain identical patches & same MIDI clips
• Fixes issue where MIDI-learning a patch-load action in patch browser, while Sort mode is "MIDI learn" could cause plugin to hang-up
• Various other minor bug fixes and performance enhancements
• Fixes issues with host automation parameters in Logic Pro 10.5
• Fixes bug where existing automation assignments were deleted after Unlearning an automation assignment
• Fixes bug where new automation IDs were incorrectly assigned after Unlearning an automation assignment
• Fixes intermittent crash when opening saved Logic Pro X projects on macOS 10.15
• Fixes bug where patches in user libraries were not listed in alphabetical order when STEAM was on an APFS drive
• Improved Authorization process and GUI layout
Also downloaded a StylusRMX Update I'd missed:
Stylus RMX Software 1.10.3d (Version History)
• Fixes issue where auditioning grooves in the Elements browser did not display a speaker icon next to the playing groove
• Fixes issue where dragging Edit Buffer grooves up/down in the browser did not work correctly
• Fixes issue where right-clicking on the Favorites ADD button (to select an edit buffer) would add current groove to incorrect edit buffer (one off)
• Fixes issue where clicking a groove/element near the bottom of a longer groove/element list would cause the list to scroll in an undesirable way
• Fixes issue is Kit mode where the Kit Part names could disappear after saving the host project in Cubase 11 or 12
• Fixes responsiveness issues with LFO up/down stepper buttons
• Removes extra speaker icon from Groove Elements browser
• Adds missing 9th output ("OUT I") to Edit Group Output menus
• Adds "Show Credits" button to Credits page and improves pane exit behavior
• Adds plugin format info to software version text on Splash Screen
• Fixes text and icon alignment issues in the Groove Suites browser
• Fixes incorrect AU component version number (the version # displayed by the Logic Pro Plug-In Manager)
• Adds rescalable Interface (via "Magnify Window" in the Utility Menu)
• Adds new Splash pane design with 'Get Updates' button for Smart Update.
• Fixes crash that could occur if two or more instances were playing sounds from the same suites and user changed suites
• Mac only: Fixes issue where the GUI could freeze when loading a file with a backslash character in the name
• Fixes issue where tempo-synced effects placed in the Aux effect racks did not sync to the host tempo
• Fixes issue where active notes could get cutoff
• Fixes issue where the Edit Group menus on the Edit page could disappear after viewing the Master FX rack
• Fixes issue where some effects sounded wrong after host sample rate changes (VST3 only)
• Fixes issue where FX could change sound based on host buffer size
• Fixes issue where patterns & repeat did not work properly in Chaos pane
• Fixes issue where groove lock data on Timing pane was not read properly from songs and multi files
• Fixes issue where MIDI file dragged from groove browser in Groove mode behaved as it if was in Slice mode
• Fixes issue where Host Sync control values were not linked for all 8 parts
• Fixes issue where effects in Inserts racks sounded wrong after host sample rate changes
• Fixes issue where some hosts did not display the correct MIDI file name after drag-and-drop import
• Fixes issue where MIDI groove drag-and-drop did not work in some DAWs (DP10 and FL20)
• Fixes Mac-only issue where RMX failed to detect a SAGE alias at startup.
• Adds a ninth audio output bus, labeled "OUT I" in the Output Assignment menu for each Part on the Mixer page
Fixes issue with the SAGE Import feature on macOS 10.15
• Fixes bug where grooves in user libraries were not listed in alphabetical order when SAGE was on an APFS drive
Old 09-28-2022, 12:14 AM
DonaldM's Avatar
DonaldM DonaldM is offline
This looks really interesting. Thanks for the heads up!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 10-04-2022, 06:37 AM
DonaldM's Avatar
So I finally got round to downloading this last night. Its a pretty nice feature. But apparently it is only available when running Omni in standalone mode. When I opened Omni inside PT, the option wasn't available. That's disappointing.
Free Update for Blue Cat's Axiom, Destructor and Free Amp bluecataudio AAX Plug-ins 1 10-22-2018 06:08 AM
Capture Punch Capture Shortcut Daniel Sasso ICON & C|24 3 03-07-2012 10:56 AM
Is the 7.4 update free? djmichael.london 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-17-2008 08:36 AM
Join vs. Capture+ Punch Capture.... colinweeks ICON & C|24 7 02-28-2007 09:11 AM
Digidesign HELP,my FREE update is NOT free!!! $140 john_tardy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-08-2003 04:03 AM
