Old 06-23-2022, 10:07 PM
Rokit88 Rokit88 is offline
Default Re: Microphone Muffled?
Yea I don't know what's going on. Do you think the power amp is going bad? It's like very bad quality recording. I tried the low latency and it's still the same. It's almost like maybe the dihi 003 is going bad? I tried to record in a different program (samplitude) and it sounds the same, so I know.its not pro tools.
Old 06-24-2022, 12:48 AM
The only things I can think of are...
You are monitoring though via a low latency monitoring path while tracking and for some reason that's different. Disable low latency monitoring and set the IO Buffer size large so you can hear the latency to be sure it's in software monitoring mode, leave it that way while you record some test tracks.
You are playing back the recorded audio and monitoring at different levels. One of the different levels might sound better to you, often the louder. And it may be easier to do this if you have the record and playback faders are Unlinked (in Preferences>Operation>Record). Measure the output level in the master fader meter and match them for both software monitoring and playback.
You maybe have hidden tracks/routing with plugins on them.
You have a corrupted session, or messed up Pro Tools. Reboot the computer. Trash prefs and try starting with a new empty session (not from template).
You might also find something by poking around with a sine wave from the signal generator plugin driving an output feeding into a mic or line input.
Muffled Audio apollo19 Tips & Tricks 5 11-22-2013 06:16 AM
muffled playback? TheLibrarayTim Pro Tools 11 3 07-25-2013 08:08 PM
Muffled playback pumpkinheady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2006 06:11 PM
Mp3 Bounce Option muffled???? thissucks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-31-2004 06:48 PM
Mix sounds muffled toadiesXJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-22-2002 02:52 AM
