D-Verb: Why Low Pass Setting AND Hi Freq. Cut?
Why have both?
Re: D-Verb: Why Low Pass Setting AND Hi Freq. Cut?
"Six of one, and half a dozen of the other."
Very good question. Phil
SoundPunk | Pro Tools Tips & Tricks |
I'm not in front of my Mac right now, but typically a LP filter is a steep filter that cuts off anything above the set frequency.
A high frequency cut would typically have a gentler slope, just "toning down" the high frequencies - like a treble control. I'll be working in the studio tonight, and double-check this against Dverb...
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
I'm not sure, but I think that one filter works on the signal before it goes into the reverb, the other one filters the sound coming out from the d-verb plug-in.
??? Gigi |
That’s precisely what they do, Gigi.
And they have very different effects on the reverb tail. F.ex I would often cut the highs of a vocal going into dverb to limit the amount of essing and not cutting so much of the actual reverb to keep it "sibly".
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Is it the high cut that is "pre verb?"
Hi Freq Cut:
-This parameter controls the decay characteristic of the high frequency components of the reverb. It acts in conjunction with the Low Pass Filter control to create the overall high frequency contour of the reverb. When set relatively low, high frequencies decay more quickly than low frequencies, simulating the effect of air absorption in a hall. Low-Pass Filter: -This parameter controls the overall high frequency content of the selected reverb by allowing you to set the frequency above which a 6 dB/octave filter attenuates the processed signal. Brent |
Cool. Thanks Brent
recording in hight freq setting? | bonzerboy | General Discussion | 6 | 11-15-2012 07:15 PM |
Focusrite d2 wrong Hi Pass setting | wasabi | Pro Tools TDM Systems (Mac) | 0 | 01-07-2007 09:04 AM |
Need a killer vocal verb setting for D-Verb | tmoc-rocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-21-2005 08:51 AM |
Verb setting for vocals | Sounder | Tips & Tricks | 2 | 03-05-2001 08:14 AM |
A good verb setting? | Sounder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-02-2001 05:44 PM |
