Old 01-11-2017, 12:33 PM
Jerreco Jerreco is offline
Default Top text cut off (file, view, etc.)
Hey, guys I'm currently using pro tools 12 (on windows 10), and I noticed that the top text is cut off every-time I open it. I've tried changing my screen resolution, maximizing, resizing pro tools without success. I am using two screens, one using Hdmi, extinding to another using VGA. I'm just wondering is there a way to resize the top text in pro tools, or even resize that portion of the pro tool window?
SOLVED
Haha, right after I posted this I solved the issue. I just right clicked pt.12>Properties>compatibility>disable display scaling on high DPi settings. I will leave this post up for anyone having this issue.
Old 07-18-2022, 04:32 PM
xander1313 xander1313 is offline
Default Re: Top text cut off (file, view, etc.)
Thank You would've never figured that out
Old 07-29-2022, 05:03 PM
bford8888 bford8888 is offline
Just want to add a comment to your solution. I spent quite a bit of time looking for Properties in Pro Tools. I finally right-clicked the Pro Tools icon on the desktop and found the Properties you were referring to. Hope this helps other folks to take advantage of your solution. Thanks much for providing this solution.
preset file to text converter is here! singtall Eleven Rack 8 11-24-2012 10:06 AM
Export markers as text file? peter5992 Post - Surround - Video 3 11-22-2011 06:42 PM
Export timecode in text file :Rob: 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-11-2009 07:29 PM
Export Digibase comments as a text file? rhumphries Post - Surround - Video 2 08-04-2006 05:21 PM
text file thx1138 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-15-2004 05:04 AM
