Old 12-16-2010, 05:48 PM
johnpaulgeorgeringo johnpaulgeorgeringo is offline
Default Native Instruments B4 II and PT9HD/Snow Leopard
Does anyone know if B4 II works in PT9HD and Snow Leopard?
Appreciate all replies.
Thanks!
Mark
Old 12-16-2010, 09:44 PM
nst7 nst7 is offline
Default Re: Native Instruments B4 II and PT9HD/Snow Leopard
According to their website, it's not compatible with Snow Leopard. It was discontinued last summer.
Old 12-17-2010, 01:54 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks!
Mark
Its not supported anymore, but i had it installed and working when i first installed 9. i have since had to revert back to PT8 to work. But i am in the process of a 100% fresh install of SL and PT9.
To get B4 working you have to install an early version of the software!! I upgraded from Komplete 4 and B4 continued to work, but to install B4 on a new system would be a bit tricky, as the old installers don't work and you have to jump through hoops to get it installed.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-17-2010, 03:34 AM
DetroitT's Avatar
DetroitT DetroitT is offline
I use it. The trick was to get the serial number from an older install (G5 for me).
Same for Spectral DDL and Vokator, Pro-53 (All running)
OS 10.6.5, Pt's HD 8.1cs2
PT9 when time permits but for 8.1 SL it's good for now.
MP-12core 12 GB 3 vid-monitor.
Old 12-17-2010, 09:32 AM
Steve@ZooWest Steve@ZooWest is offline
Is there any way to acquire B4 now?
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 12-17-2010, 10:16 AM
Originally Posted by crizdee View Post
Chris
Hey Chris, I'm seeing this for sale on ebay etc. and a partner of mine still has the 'old' disc. My new system seems to be behaving so trying to avoid problems if I can. When you say the installers don't work, what kind of hoop jumping are we talking? :)
Thanks man. But just to clarify, this is not on PT9 right? So the installer did work for you?
Old 12-17-2010, 10:27 AM
DetroitT's Avatar
There was (is) a leopard patch for install that worked. Then I manually added my serial in service center and it authorized. I have not gone to 9 yet.
8.1 cs2
Old 12-17-2010, 10:36 AM
8.1 cs2
Thanks for the info. Appreciated!
Old 12-17-2010, 10:56 AM
To Steve@Zoowest,
It's possible you may be able to still find a new copy at some dealer somewhere, or on Ebay, or buy it used from someone (NI does allow license transfers).
However, they've recently come out with a new Kontakt player pack called Vintage Organs. It seems to be very in depth samples and sounds pretty good to me.
You can buy it separately, but it's also included in Komplete 7.
You can check it out here:
http://www.native-instruments.com/#/...intage-organs/
Old 12-17-2010, 09:21 PM
tedcanman tedcanman is offline
I have the old B-4-1 physical/midi control box, and I hope that when I am done with all my PT9 upgrading that perhaps I can get that to work with - say - the Vintage Organs that will be going on my system with the Komplete7.
Any bets on if it will ever work??
Native Instruments FM7 Installation on ProTools 10.32 on OSX10.68 Snow Leopard Sugarc4t macOS 6 04-05-2013 04:40 AM
Snow Leopard 10.6.8 with HD Native Pro Tools 9.0.3 midnightrambler Pro Tools HDX & HD Native Systems (Mac) 28 08-08-2011 11:59 AM
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard DigiTechSupt Virtual Instruments 0 01-07-2010 11:08 AM
A.I.R. Virtual Instruments Updates for Snow Leopard Compatibility DigiTechSupt Virtual Instruments 0 01-07-2010 10:19 AM
> Native Instruments Komplete, PT and Leopard Howardk Pro Tools TDM Systems (Mac) 4 08-18-2008 11:00 AM
