dual 1ghz owners, are u happy ?
dual 1ghz owners, are u happy ? [img]images/icons/grin.gif[/img]
I'm ready to make the jump for a new( or old) 1 ghz. any warnings, hints, thoughts ....... very welcome [img]images/icons/frown.gif[/img] |
Re: dual 1ghz owners, are u happy ?
Mine works great with a HD2 system.
I've heard that the fans are loud in that model, but I can't tell since mine is in a Marathon rack, and doesn't have the original fan any more. I'm hoping that OS-X and PT6 will unleash the power that's not being used right now.
www.barnabas.com Barnabas MultiMedia |
I have the pre-mirrored doors model & I'm using it with HD3 and love it. It has been my most stable Mac since the IIx!
I literally use it for days without rebooting using PT, Final Cut Pro 3, and Photoshop 6. I usually have a web browser and e-mail open in the background too ( I did have to turn off automatic e-mail retrieval though - if I got a big e-mail while working in another app bad things would happen). I've got 3 IDE hard drives inside and a couple of Firewire hard drives hooked up externally. It is rack mounted inside a home-built Isorack, with internal temperatures typically running 84-86 degrees. The mirrored drive door models are a lot louder than this one. As a one room studio I'm happy I have the quieter model. Good luck, Jeff D. |
I have the mirrored doors and I can just agree to what the others already mentioned. (I run a HD 3 on it). The baby is more stable than my Mix+++ Rig on the 9600. You can place lots of Eide Drives internal, great for fast backups.
go for it daniel |
be aware of the noise the mdd makes!
i have mine in a rack with a glasdoor...and it's still louder than a vacuumcleaner. this is very annoying...but...nevertheless..the machine's power is great....(unless u want to use it with a digi001...than u have to change the logicboard...but that's another story..) |
Other than an annoying Type 2 error when booting Pro Tools 5.3.1 (known issue with "Classic" OS 9.2.2), the system is really stable. I've got 3 of them and I haven't had any crashes after Pro Tools gets started.
If you're going to get one, I suggest you purchase a seperate IDE to use as a dedicated OS 9 drive instead of partitioning the HD that comes with the computer. As for the fan issue, some of the fans rev up to full blast every few minutes. Apple has a great firmware update if your computer does this. Good Luck
Bryan Jackson Independent Audio Systems Engineer Burbank,CA / Las Vegas, NV |
It's not just that the fan noise is so loud, it is loud in a register that seems to cut through other background noise. Aside from that, it is a terrific machine.
The dual 1ghz machine runs my general office / internet duties. I put it in sleep mode when working in Protools - running on a single processor 733 G4. That works well too. |
So, just to clarify, with the Apple firmware update stopping the periodic fan bursts, is the resulting low-level fan noise still higher than on previous generation G4's? Significantly?
Malcolm |
ok, apart from the fan noise, is there any more reason why Ishould go for the older model, or do think I should opt for the new model ?
D Command Owners - Happy? | JSR | ICON & C|24 | 8 | 12-03-2006 03:54 PM |
500 Mhz G4 to Dual 1Ghz G4 | fmckinnon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-09-2002 10:09 PM |
mac 933 vs. dual 1ghz | waves3 | Pro Tools TDM Systems (Mac) | 3 | 03-31-2002 11:28 AM |
Anybody using 001 with new Dual 1ghz G4? | stink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-25-2002 07:42 AM |
HD owners!! R U HAPPY with the mixes @ 44.1 now? | roijin | Pro Tools TDM Systems (Mac) | 0 | 02-13-2002 10:00 PM |
