Kontakt and PT
I'm using Kontakt 2.2.4 with PT (7.4)
I held off on version 3 because of all the instability reports I'd heard early on with PT. And 2.2.4 is pretty darn smooth. Problem I'm having is I can't get PT (7.4) to see more than 1 stereo output from kontakt. It sees all the mono outputs, but not stereo. Wondering 1. Am I doing something wrong? 2. Did v3 fix this? 3. How is version 3 with PT now? Thanks, Rob |
Re: Kontakt and PT
this happens on version 2 and 3
it does this on a mono track with stereo out of Kontakt it requires that it is activated on a stereo track for stereo out
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Re: Kontakt and PT
If I understand you correctly, you're saying that if set up properly, PT should be able to see more than one stereo channel from Kontakt.
Thing is, in Kontakt's outputs, I'm given channel output options st1(1) st 1(2) st2(1) st 2(2) surr. 5.1 (1) surr. 5.1 (2) surr. 5.1 (3) surr. 5.1 (4) surr. 5.1 (5) surr. 5.1 (6) then the aux channels, then the "unassigned" mono channels so for a 2nd stereo channel, i have to choose to send out of 2 mono channels. Then I set up my stereo track in PT, and look for input sources from Kontakt and all I see is st. 2 aux 1 aux 2 aux 3 aux 4 and the auxes are not usable in this situation. so i guess, i don't get what you're saying. thanks, rob |
PT presets from kontakt 4 not opening in kontakt 5 | table17 | Virtual Instruments | 0 | 02-06-2012 12:13 PM |
OT: Kontakt 4, 8.0.1, W7... | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-11-2009 11:43 AM |
Kontakt 2 Stand Alone vs RTAS, Kontakt vs Giga | ryan de topanga | Pro Tools TDM Systems (Mac) | 18 | 05-17-2005 06:36 AM |
Anyone using Kontakt with LE? | mannikin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-29-2005 09:38 PM |
