Old 10-25-2007, 11:48 AM
calpilot calpilot is offline
Default Substitute Mbox Mini for Mbox2 Pro
A newbie question, but I couldn't find an answer in the search:
Am currently running LE 7.3 with an Mbox2 Pro at home, and would like to get an Mbox Mini to take on the road.
Will a single LE 7.3 installation allow me to just "plug and play" the mini as the hardware interface without any hassles?
Thanks!
Jeff
Old 10-25-2007, 12:31 PM
mnoxious mnoxious is offline
Default Re: Substitute Mbox Mini for Mbox2 Pro
Quick answer, yes. Depending on which system (mini or pro) you started your session every time you open a session using the other hardware you will receive a note saying that your I/O has changed (because you no longer have the same input/output options because you changed hardware.)
Another thing to keep in mind is that the Mbox 2 Pro has support for up to 24bit/96kHz, while the Mbox 2 mini only supports up to 24bit/48kHz so if you have a 88.2 or 96k session it won't open using the mini unless you apply sample rate conversion.
But I go between my Mbox2 mini and a 002 all the time with no problems, I just can't use the mini on projects that are at 96k (which for me aren't many).
Hope this helps.
Mark
Old 10-25-2007, 02:57 PM
Perfect!
Thanks for the quick response...I certainly appreciate it.
My MBOX2 and MBOX2 mini won't work in Europe? jonslaten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-25-2009 03:12 PM
MBox2 Mini - How do I have Windows sounds play through MBOX? Jaison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-19-2008 05:51 PM
mbox2 pro and mbox mini on same macbook? sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-15-2007 06:57 AM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
Mbox2 Mini vs Mbox 1 jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-25-2006 01:56 PM
