Creating a new session
Please help. I've just installed ProTools 6.9 LE on a PowerBook G4. I have an external hard drive solely for audio recording. I try to create a new session, and direct the software to use my external drive for the creation location, but always get this message:
"Session must be on an audio record volume." I can go no further. How do I resolve this problem? Thanks for any help. |
Re: Creating a new session
Please list what External Hard Drive you are useing? Also Is it firwire or USB 2.0. Also check your disk allocation menu.
I'm using a Maxtor 7200 RPM drive, USB 2.0. I can read and write to the drive. Thanks for any help. Oh, I have 1 GB of RAM in the PowerBook. Do I need Firewire instead of USB?
Yes.... I would suggest a good Glygh Firewire HD, (very dependable for long sessions).Plus, (I believe it's suggested to use FW HD's in the PT Manual) Then if you are having problems... with "volume errors" , not being recognized... then get the 6.9.2 update. There's info all over the DUC on how to fix that certain error, go to you top menu & (under your Workspace menu) and change the (V) to (R) on both your G4 and your external drive.......worked for me. DUC Forum "rocks" Helps me out! Good luck.
Thanks a bunch for the help. Maybe I should get a FW drive... it would be faster. Just more money to spend, I suppose. (I just bought the Maxtor.) Anyway, I just bought an HP Pavilion laptop... then decided the Powerbook would be better, so bought one of those. I'd just like all this stuff to work together for a change. I can't help wonder why there are so many "issues" with different things. Guess it's the learning curve. Thanks again.
Creating New Session From Old | mrgroovy | Pro Tools 10 | 1 | 05-07-2013 03:45 PM |
creating new session error | S.TaylorRCC | Windows | 4 | 10-02-2011 06:27 PM |
Creating an independent new session | pugman84 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-11-2005 05:36 PM |
Creating a stereo mix from 5.1 Session - how? | Helge Krabye | Post - Surround - Video | 3 | 03-07-2005 02:51 PM |
Creating Tracks within a session | Steel City | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-02-2005 02:19 PM |
