  #61
Old 09-03-2021, 03:38 PM
Eric Lambert's Avatar
Default Re: MIDI in 2021 and BEYOND
I haven't read all 6 pages but I know that PT can still learn quite a lot from Logic when it comes to MIDI. It's almost B&W vs. Color in this regard, one being so far advanced relative to the other. Opcode Vision, circa mid-90's, floored PT in MIDI editing almost 30 years ago. PT's MIDI implementation hasn't changed in ages, indicating that Avid doesn't sense enough of a demand from their users. That's odd to me, as someone who works so heavily in MIDI, but it is what it is.
  #62
Old 09-03-2021, 03:47 PM
foxes's Avatar
foxes foxes is offline
Originally Posted by innesireinar View Post
Unfortunately when mixing I miss the PT mixer. I hope Steinberg will improve this in the future.
Same thing with S1
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #63
Old 09-03-2021, 04:33 PM
kmack kmack is offline
Allow us to use Midi controllers to map non-VI plugin parameters.
  #64
Old 09-03-2021, 05:30 PM
ejsongs ejsongs is offline
Originally Posted by podusa View Post
For MIDI-notes? I wouldn't think so.
I mean it to work just like the scissors tool in Logic.
I just want to be able to cut a bar by just cut the part in waveform view.
Now the notes stay in the original length and continue even if I cut the part
(EDIT: I mean Clip view, not Waveform view. Sorry for the confusion)
you can already do this. you have to cut the notes first on notes view and then cut the regions/clips.
ej
  #65
Old 09-03-2021, 07:06 PM
Sardi Sardi is offline
You can do this now if your plugins support MIDI learn. FF ProQ for example supports this and I can map controls to a MIDI controller. I also have a Eucon controller so don’t tend to use it that often, but have in the past.
But, you’re right that it could be more elegant when you compare it to other DAWs. Unfortunately (or fortunately depending on your view) their main focus is Eucon.
  #66
Old 09-03-2021, 08:48 PM
Hmm...can you tell me more? I've been trying to get this to work for some time now. Both with plugins that suppprt MIDI learn (including ProQ) and with with the built in mapping function. I even reached out to support and they couldn't help. What controller are you using and how do you have it configured?
  #67
Old 09-03-2021, 10:37 PM
podusa podusa is offline
ej
Yes, exactly.
To cut one bar, I have to change view, zoom in, change tool, cut, change view again, zoom out, change tool again…AND I can only edit one track at the time.
Try cut one bar, going in to the chorus with 20 MIDI-tracks! It takes forever.
It should work like editing audio in my opinion.
Select regions, Press “B” and hit delete, WITH the notes following my edit.
Why would it NOT work that way? I don’t get it…
  #68
Old 09-04-2021, 02:40 AM
tonwurm's Avatar
tonwurm tonwurm is offline
as a workaround I created a shortcut with Keyboard Maestro
https://www.dropbox.com/s/lfsyh5iqhc...3%201.mp4?dl=0
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
  #69
Old 09-04-2021, 04:20 AM
Has something changed since your own post #3 in this thread? https://duc.avid.com/showthread.php?...41#post2602941
There's also this thread to look at:
https://duc.avid.com/showthread.php?t=414922
You have to set up your MIDI controller first to make things work.
  #70
Old 09-04-2021, 04:25 AM
Nothing has changed. But I should have specified in that post that MIDI learn works for me with VI only. Not on other plugins on audio tracks.
And yes, I have setup my MIDI controller properly, at least to my knowledge. I can use it to control parameters in virtual instruments. I can control transport functions. But that's it. So I'm wondering if I'm missing something.
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
Cut/Insert Time still shifting markers & MIDI clips in PT 2021.6 take77 Pro Tools 1 07-09-2021 10:53 PM
2021.6 hangs when deleting audio or MIDI clips innerbooty Pro Tools 5 07-02-2021 07:16 AM
Update to 2021.3.1 now midi and software unstable biggamen Pro Tools 9 06-03-2021 05:54 AM
